Clari-T in cars and RV's
gilbodavid
« on: 15 May 2005, 12:11 pm »
I spend much time in my RV with its 12v leisure battery. I assume hooking up the Clari-T would be a good idea. thinking about some small Omega speakers in there too. Havent sussed vinal playback in this situ, but am very tempted by this idea. Anyone done it?
Vinnie R.
    • http://www.vinnierossi.com
Re: Clari-T in cars and RV's
« Reply #1 on: 15 May 2005, 09:03 pm »
Quote from: gilbodavid
Hi Gilbodavid,
Sure, the Clari-T is definitely portable, but you must use its internal battery.  For your RV, you can use a power inverter (a small 30 watt inverter will do the trick) that will allow you to plug in your charger.
If you want the smallest Omega Speakers, these new ones are the way to go: http://www.redwineaudio.com/Omega_Mini_ME.html
If your RV's a rockin, we won't come a knockin'!     :guitar:
gilbodavid
« Reply #2 on: 23 May 2005, 11:25 pm »
Thanks for the swift reply Vinnie. Just sold my rv, and off to germany to get a larger one next weekend. then i shall seriously commence rv musical heaven
