my budget would probably be between $125 and $200.
Does anyone have something that would work for the OP in a closet? I thought about sending him a NuPrime IDA-6 that I don't use, but I don't think it has enough power to drive a 600 series B&W at 60w per channel. I looked at the current 600 series, and the two monitors are 84db and 88db. I was just going to have him pay shipping. Magnus, do you know the sensitivity of your speakers? Someone/s please chime in here, let's see if we can help Magnus out.JCarney
That's very generous of you JCarney. 60 wpc should be fine unless Magnus likes to CRANK it up. However the lack of a phono input in the Nuprime would be an issue for the turntable.
I have a Hafler DH 200 with Musical Concepts mods you can have for free if that helps. You’d need to source a preamp, but at least the amp would be free. Let me know if that’s something that would be fun to play with.Mark
Magnus:If no one has posted that they have something with a phono stage built in they are willing to send you by tomorrow afternoon, I'll reach out via PM to get your address and get you a shipping amount. If you search for phono stages you will find a couple under a $100. The Fosi X2 tubed phono stage is currently $70 directly from Fosi Audio. The IDA-6 also has a built in DAC, just so you know.https://fosiaudio.com/products/fosi-audio-phono-preamp-for-turntable-preamplifier-mm-phonograph-preamplifier-with-gain-gear-mini-stereo-audio-hi-fi-pre-amplifier-for-record-player-with-dc-12v-power-box-x2?variant=31406173159508¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organicJCarney
