Industry Circles
Bryston Limited
BR20 DSD Support
BR20 DSD Support
0 Members and 1 Guest are viewing this topic. Read 1814 times.
shaun666
BR20 DSD Support
17 Oct 2024, 10:51 am »
Hi,
What is the maximum DSD resolution possible with the AES ports?
Am I right in thinking only one port can be used at a time?
The reason I ask is some streamer manufacturers use 2 AES ports simultaneously
Looking forward to getting my BR20 in a few weeks
Shaun
PeterG
Re: BR20 DSD Support
17 Oct 2024, 03:07 pm »
afaict, the AES ports can only receive up to 24/192 PCM, no DSD…..DSD through the USB port or HDMI. I have the BDA 3.14 which has the same DAC as the BR 20….DSD through USB or HDMI only ….have tried DSD through AES on my 3.14 and doesn’t work
shaun666
Reply #2 on:
17 Oct 2024, 04:10 pm »
As I thought
Many thanks
Shaun
jcn3
Reply #3 on:
17 Oct 2024, 09:32 pm »
in the manual for the br-20, it says max via aes/spdif/optical is 24/192.
Industry Circles
Bryston Limited
BR20 DSD Support
