NX Center build project
0 Members and 1 Guest are viewing this topic. Read 8023 times.
Huskerbryce
« on: 16 Oct 2024, 03:49 pm »
Last June I built a pair of NX Oticas for my home theater room.  I love them to death so I decided to build a matching center speaker.  I have not received the flat pack yet so I have been working on the crossover.  I ordered quite a few upgrades for the crossover.  Many of which are probably unnecessary but I wanted to cut no corners on quality.  Over the years of building many speaker designs I have never been able or willing to go the extra mile on crossovers.  Ive always gone the cheap way out.  With the Oticas I wanted to go all in.  With the Otica build it was a but of a challenge to get the larger upgraded crossover parts to all fit on the triangular form factor plate to fit in the cabinet.   With the NX Center I have planned a much larger plate for the crossover to lay horizontally flat.  So far the larger crossover has been a delight to work with compared to the cramped Otica ones.  Plus, there is only 1 of them.  😁
Early B.
Re: NX Center build project
« Reply #1 on: 17 Oct 2024, 02:04 am »
I'm interested in your build. I dream of buying two NX Centers to use as main speakers.
Huskerbryce
« Reply #2 on: 17 Oct 2024, 02:15 am »
About an hour after I posted the build project thread I received notification that UPS is delivering the flat pack tomorrow.
Huskerbryce
« Reply #3 on: 17 Oct 2024, 02:36 am »
I am building the NX Center crossover in the same way I built my Otica crossovers.  I am using plexiglass as the base for mounting all the components.  Drilling holes and running all the wiring shrink wrapped in black, over a black base.  This way, you wont see the “mess” underneath.  Looks very clean.  I use 3M hemispherical rubber standoffs.  Then on the black base use plastic chromed feet so there is no metal messing with the inductors.  Looks metal, all plastic.
Initially I planned to use the supplied sonicaps and GR wire wound resistors with a foil inductor upgrade on the mid.  I received all the parts and just couldnt help myself but to order “upgrades” for everything.  The only thing I didnt customize was the large inductor for the lower woofers.  A copper foil of that value would be the size of a basketball and cost a fortune.  I looked into into it.  Not worth it.
For the rest I had planned to use all hard to find miflex copper foil caps (miflex out of business) until I saw some of the values could not be sourced.  I settled on mostly a complete Vcap ODAM nest of caps utilizing Deulund silver copper CAST hybrid bypass on the tweeter and miflex coppers on the mids.  I used miflex coppers on the other smaller value caps as well.  For the resistors I like the Path Audio resistors.  I know Danny doesn't like them because they have metal ends.  My personal choice only on those.  I upgraded all the inductors to copper foil except the big woofer coil.
The major point of back and forth was using the provided tube connectors.  I elected to go with pure copper binding posts.  I know, I know, the higher mass copper might lose performance.  I just like the flexibility and look and ease of installation that a solid copper post provides.  My really nice, already ran through the wall, speaker cable utilizes bananas and this is just a simpler solution for me.
BrandonB
« Reply #4 on: 17 Oct 2024, 10:11 am »
This is going to be nice.  What HT processor are you using?
Huskerbryce
« Reply #5 on: 17 Oct 2024, 01:08 pm »
Emotiva XMC-2.
Huskerbryce
« Reply #6 on: 17 Oct 2024, 07:06 pm »
Still waiting on a few parts to complete the crossover.  So far I have a good start.
BrandonB
« Reply #7 on: 18 Oct 2024, 03:02 am »
That is nice looking.
Huskerbryce
« Reply #8 on: 18 Oct 2024, 05:29 am »
Thank you Brandon!  I tried to make them look like I don't totally suck at this…lol  In reality I am a total amateur and learning.  I like any help I can get.
jmimac351
« Reply #9 on: 18 Oct 2024, 10:27 am »
The crossover looks great!  When things are laid out with symmetry it looks "right".
jmimac351
« Reply #10 on: 18 Oct 2024, 11:59 am »
Do you know what the thinking on that is... whether the tweeter needs to be rotated, crossover redesigned - or is it OK to use for L / R main speakers, as-is?
jmimac351
« Reply #11 on: 18 Oct 2024, 12:01 pm »
Looking forward to seeing how this goes together!
Early B.
« Reply #12 on: 18 Oct 2024, 07:30 pm »
I don't know. I'm only half serious, but I'm considering it strictly for the cool factor. Imagine 8 feet of horizontal drivers sitting on top of three dual OB servo subs!
Hobbsmeerkat
« Reply #13 on: 18 Oct 2024, 08:38 pm »
it technically can be used like it is, but tweeter dispersion would be better if it was rotated vertically.
jmimac351
« Reply #14 on: 23 Oct 2024, 12:52 am »
I know the driver count is the same as Otica, but I like the idea of a symmetrical driver layout, like the NX-Treme, but in a more manageable package.  It could have feet / legs to raise it to custom height.  It would be a different look and I bet would look good.
Just thinking thru OB options...
Huskerbryce
« Reply #15 on: 26 Oct 2024, 08:21 pm »
Got the cabinet glued together.  Went together with not much effort.  Its a very large center speaker.  Temps dropped into the 50’s-60s so the wood glue may take a little longer to set fully.  In another 24 hours or so I will start the tedious process of sealing, sanding priming and painting.  The absolute worst part of speaker building to me.
Huskerbryce
« Reply #16 on: 28 Oct 2024, 06:02 pm »
Today I did several coats of a 50/50 wood glue to water seal.
Huskerbryce
« Reply #17 on: 28 Oct 2024, 06:19 pm »
Got the crossover functional.  Still waiting on one more miflex .1 uf bypass cap.
I.Greyhound Fan
« Reply #18 on: 28 Oct 2024, 06:28 pm »
Wow, the crossover looks awesome.  I like the caps and foil inductors.  It is going to sound awesome! Just curious, why the Iron Core laminated inductor?  Price maybe?
Huskerbryce
« Reply #19 on: 28 Oct 2024, 07:38 pm »
That iron core inductor is a higher value inductor. It’s the one for the lower woofers. To get a custom-made copper foil inductor of that value was going to cost more than a new class A monoblock amplifier for the center speaker.   I called Bridgeport magnetics based out of Connecticut just to see what a custom-made inductor of that value would cost.   Freaking a lot.   I elected to go with the iron corn conductor. Plus even if money was completely not an object, and I had them custom make a copper foil inductor of that value. It would be the size of a basketball.
