Integra 9.8 SSP no longer going into Dolby Digital. What to do…???
jriggy
I have an old Integra 9.8 SSP here. We use it for streaming movies and shows with an AppleTV over HDMI. We recently had a 3 day power outage and when all was back to normal, the 9.8 was not.
When streaming a movie now there is simply no Dolby Digital or DTS that will engage. Only the analog DSPs will engage, like Pro-Logic, ect.
I’ve checked all settings in the AppleTV and in the 9.8, I see nothing amiss there.
Could the issue be the AppleTV?  Or is it definitely the Integra?? BTW, I did swap the HDMI cable just to be sure on that, too.
I love this unit because of its multi-band and multi speaker Equalizer capabilities.
So I’m asking a few things here: Is it definitely the Integra? Could it possibly be the AppleTV? Can/Will this function return(lol)? Should I buy another used 9.8 for cheap? Should I look at something new, and if so, what?
Looks like I’m looking for y’all to make my decision for me! LOL. If I got something new to me, I think I’d want to keep it under $1500 used and like I said it must have a good EQ and of corse have nice clean sound like these Integra units were known for in their class.
I’m using a Rotel 5ch amp and Mirage OM6 towers and OMC2 center for our little 3ch set-up
Any thoughts, directions, comments about the issues OR opinion on replacement with same or different ect..
Thanks all!
 Jason
Doublej
I would try a factory reset on the Integra and/or the Apple TV to see if you can get it back. Before doing so, I would go into the configuration screens and take photos of the settings. You have to manually reenter them, but at least you'll know what the values before the reset.
I would also confirm that is not a problem caused by a software update to Apple TV. A web search should be able to tell you if others are experiencing the same problem.
Lastly before giving up on the Integra I would post the question and search the Home Theater forums to see what others have to say about your issue.
If you determine it is the Integra, I would buy something new. I would not take a chance on a used 15 year old unit. Pickings are slim for AV Pre-Pros. Marantz and Emotiva are brands that come to mind. If you want an AVR with pre-outs you have more selection. For these I would look at Anthem, Denon, and Marantz.
Again lots of information about products on the Home Theater forums.
Good luck, keep us posted.
How about other streaming sources? How about traditional disc media?
Double check all settings. Re-seat connections.
It's possible the power outage cause a spike. If it is the unit, Karma it rather than throwing it away.
jriggy
Thank you for helping! Great suggestions!
I did a search and initially didn’t see anything. But today I see that this is now most likely an ApplyTV update issue.
I’ll keep investigating a little but looks like it’s only a somewhat known issue for about a month now from an update. And some are saying they(Apple) needs to know this is happening to more people so they’ll look into it.
