C&C linear power supplies
0 Members and 1 Guest are viewing this topic. Read 14304 times.
WGH
Re: C&C linear power supplies
« Reply #20 on: 25 Sep 2024, 10:25 pm »
Any recommendations for a USB C terminated 5 volt LPS for a WiiM Pro Plus?
How long a cable do you need? Monoprice has USB C cables from 1.5' to 10'. Snip off the end you don't need.
https://www.monoprice.com/search/index?keyword=usb%20c%20cables&sort=sellingPrice%20asc&TotalProducts=102
Acopian 5EB200 5v 2amp linear power supply - $20 on eBay. (List price $215)
I use the Acopian 5EB200 linear regulated power supply inside my music server. Not children with forks friendly.
Load 0.25%, Line 0.05%, Ripple 1 mV RMS
https://www.acopian.com/store/productdetail.aspx?q=i574
Poultrygeist
« Reply #21 on: 26 Sep 2024, 10:08 am »
From experience I know a linear PS can make a big difference in the SQ of DAC's, amps and pre-amps.
Might we expect the same degree of improvement with a streamer?
Poultrygeist
« Reply #22 on: 26 Sep 2024, 01:19 pm »
Is the Acoplan 5EB200 in the link a switch mode power supply? Linear power supplies are generally quieter and produce less noise as they don't switch on and off.
I have a Meanwell which is one of the better SMPS but it doesn't compare to my Astron linear regulated. I paid $35 for the Astron on eBay in this picture. It's massive and heavier than most amplifiers.
WGH
« Reply #23 on: 26 Sep 2024, 02:56 pm »
The Acopian 5EB200 is a linear regulated power supply
Here is link to all the Acopian Mini-Encapsulated Linear Regulated power supplies
https://www.acopian.com/single-l-screw-m.html
Doublej
« Reply #24 on: 29 Sep 2024, 12:51 pm »
WGH - Thanks for the cable tip. I found a USB C wiring diagram so now I feel comfortable using a modified cable.
Poultrygeist - I am using the DAC in my WiiM streamer so I should hear an improvement in my setup.
Poultrygeist
« Reply #25 on: 14 Jan 2025, 09:23 pm »
A couple of weeks ago I bought a Fosi ZD3 DAC on sale for $150 at Amazon and considering its multitude of features I believe it would qualify as C&C. I spent some time with it before adding the low profile 12V Astron linear regulated PSU ( bottom left ) so the difference would be more recognizable and what a difference it was. I would be shocked if the Sparkos op amps I plan to add in the future would provide anywhere close to a comparable upgrade.
