Modwright PH 9.0XT with the Hana ML cart?
Zuman
« on: 18 Sep 2024, 07:32 pm »
Is anyone using the Modwright PH 9.0XT phono stage with the Hana ML moving coil cartridge?
If so, are you setting the 9.0 for 100 or 250 ohms load impedance?
Thanks.
jjinid
Re: Modwright PH 9.0XT with the Hana ML cart?
« Reply #1 on: 21 Sep 2024, 06:11 pm »
I had that combination for a few years, upgraded to a Hana Umami Red.  You want to run at 100 ohms, that is nominal impedance for the cartridge.
Zuman
« Reply #2 on: 21 Sep 2024, 07:43 pm »
Thanks. I've been using the ML for about three years and I sometimes use 250 if a recording is on the dull side; otherwise I stick with 100 ohms. Are you experiencing a significant difference with the Red versus the ML?
jjinid
« Reply #3 on: 21 Sep 2024, 09:29 pm »
Yes, it's a significant upgrade.  The ML is very good for the price, but the Red is much more extended, natural, and realistic.  It's a terrific match with the PH 9.0XT.
Rocket
« Reply #4 on: 22 Sep 2024, 01:33 pm »
Hi,
No I don't but I would like to get the combo one day in the future  8)
Cheers Rod
