SOLD: NuForce STA200 Class AB Power Amplifier
0 Members and 1 Guest are viewing this topic. Read 822 times.
tlarwa
« on: 13 Sep 2024, 07:02 pm »
My NuForce STA200 amp is on the block. It's being replaced by a second beefed-up Odyssey Khartago, that matches the other one I have. I will have no use for the NuForce amp once it's replaced. Functionally, the amp works perfectly. It looks good in the rack, but there are a couple imperfections on the top cover. Nothing bad at all, but you can see them in the pics. I can get you a pic of the back if you want, I just need to pull it out of the rack. It is issue free though.
I'm the 2nd owner, and have the original packaging. I've been using it to drive the highs in my bi-amped OB speaker system, so pretty light duty usage. If you're looking for a well built, dependable SS amp, with a smaller form factor, this may be the ticket (especially for the price).  Check out a good review from TAS:  https://www.theabsolutesound.com/articles/optoma-nuforce-sta200-power-amplifier/.
Specs are:
Type: Solid-state, Class AB
Output power: 80Wpc into 8 ohms
Input: RCA analog (single-ended)
Input impedance: 51k ohms
Output impedance: 30m ohm
Dimensions: 14″ x 3.4″ x 8.8″
Weight: 13 lbs
Like I said, I have the original box. Shipping should be pretty inexpensive, and I will charge whatever my actual shipping charge is to get it to you. I wouldn’t think it’ll be more than $20 or so.
$325 + actual shipping charges. I'll be in Europe all of next week, but could ship it between now and Saturday if there's any interest. Otherwise I can ship on 9/21.
« Last Edit: 14 Sep 2024, 04:17 pm by tlarwa »
