AvantGarde horn speakers
santani
« on: 12 Sep 2024, 11:18 pm »
Looking for upgrade suggestions for Avantgarde Uno series 2 speakers (20 years old) to get the best out of bi-amping them. Thanks.
Re: AvantGarde horn speakers
« Reply #1 on: 13 Sep 2024, 04:41 am »
This thread should be relocated to a Circle that deals with speakers.
This Circle is called Karma, as in giving an item away to others for good karma.
« Reply #2 on: 13 Sep 2024, 05:39 am »
28
Letitroll98
  • Too loud is just right
« Reply #3 on: 13 Sep 2024, 12:04 pm »
They don't fit into the usual box speaker categories so I doubt there's very much experience in modding these speakers on these pages.  I'd guess that maybe the crossover might be looked at, but that's only a guess.  What qualities are you looking to improve?
Tam Lin
« Reply #4 on: 13 Sep 2024, 10:04 pm »
The Uno is already bi-amped. You supplied the amp for the two horns and the built-in amp powers the woofers. I think better results can be obtained by upgrading the components in the horn crossovers.
« Reply #5 on: 13 Sep 2024, 10:47 pm »
Around 2004 I have listened the Uno for some hours in a large music room at a local audiophile home with top BAT and DCS equips, so I could recommend dont fix what is not broken IMO.
If one like horns there is no much better than the Uno, I dont like horns but I must say these AvantGarde horns dont have the usual duck voice from the PP plastic cornets.
