0 Members and 1 Guest are viewing this topic. Read 29027 times.
Hobbs/Danny, what about making the stl file available so people can print the waveguide themselves? If not, I recommend a Bambu Lab P1S or X1 Carbon to print them, you will save a lot more time.
I've already mentioned that as an option on the product description, and I may make it an option directly on the product page.The plan is to order the P1P, as I don't plan to print in anything other than PLA, so the side walls of the P1S and extra features of X1C aren't really of much use to me, unless I was looking to print high-temperature filaments, but it should cut printing times in half over my current modified Creality Ender 3.
Hobbs, will your waveguide / cup work for the M165 driver as well, and pretty much any 5.5"-6.5" driver? Not sure if there is a voice coil depth difference that makes a different waveguide necessary.
Looks like you found your replacement for the BG Neo 8/10 tweeters. Very cool stuff guys!
It should be able to work quite well with any driver you want to pair it with.
The Neo 10 is a different animal altogether, as it's more of a midrange driver than a tweeter. The only driver we've seen that comes close is the New Radian LM10
