Wall mounted furniture suggestions welcome here
Denton J
« on: 11 Sep 2024, 02:09 pm »
Good morning,
I am thinking about wall mounting my turntable. I sure I can make one out of wood but I would rather have a metal bracket for stability and minimal material used to hold the platform up.
Is there a brand out there that does decent wall mount furniture or is this more of a DIY type of thing?
richidoo
Re: Wall mounted furniture suggestions welcome here
« Reply #1 on: 11 Sep 2024, 02:32 pm »
Pro-Ject and Rega both make several models of wall mount TT shelves.
Also Solidsteel and Pangea.
Of course you can DIY anything if you have the abilities.
Try to mount it on a wall location that is directly over foundation structure, whether the outside perimeter of house or over an internal  foundation support column. Near a corner is also helpful as the other wall stiffens the mounting wall near the corner.
Denton J
« Reply #2 on: 11 Sep 2024, 03:21 pm »
TomS
« Reply #3 on: 12 Sep 2024, 01:31 am »
I had the SolidSteel WS-5 with a maple slab on top and it was terrific
https://www.crutchfield.com/S-O75A4e48ica/p_961WS5K/Solidsteel-WS-5.html
