Qobuz
0 Members and 1 Guest are viewing this topic. Read 5266 times.
Fenek
Qobuz
« on: 11 Sep 2024, 08:45 am »
Hello, the omnia App ( Android) doesn´t work with Qobuz. The Log In doesn´t work. A friend of mine has the same issue. What´s happend?
Anybody knows a solution?
teggehifi
Re: Qobuz
« Reply #1 on: 11 Sep 2024, 04:10 pm »
I am facing the same problem. Would welcome as well if someone had a solution.
John Casler
Re: Qobuz
« Reply #2 on: 11 Sep 2024, 06:10 pm »
I recently received the message below regarding the issue.  It appears that this is a Qobuz issue affecting products other than just NuPRIME.
I'm sure once Jason sees this, he can provide more information.
<<<Our streaming module supplier is currently investigating a login issue with Qobuz that is impacting all users, including tens of thousands who are not NuPrime customers. Please stay tuned for updates.>>>
rustydoglim
Re: Qobuz
« Reply #3 on: 11 Sep 2024, 06:44 pm »
Nuprime and several other brands use LinkPlay module, and there is a LinkPlay platform problem that is affecting everyone using Qobuz.
See https://forum.wiimhome.com/threads/qobuz-no-music.4704/
Unfortunately LinkPlay is not providing the support we need.
We are investigating a solution that involve updating the firmware to use BubbleUPnP to stream Qobuz to our streamer.
Fenek
Re: Qobuz
« Reply #4 on: 12 Sep 2024, 10:57 am »
Using bubble upnp ( Android ) or mconnect ( Ios) Qobuz works well with Nuprime streamer.
rustydoglim
Re: Qobuz
« Reply #5 on: 12 Sep 2024, 03:53 pm »
Yes, that will be our recommendation.
giordy60
Re: Qobuz
« Reply #6 on: 13 Sep 2024, 01:23 pm »
But wouldn't it be better for this to implement the "Connect" function and the streaming on "Omnia Mini Stream" or any device in charge of receiving an audio flow is sent?
Why don't this do it? Despite being a request that many have made?
..Request already made to qobuz of course ......
rustydoglim
Re: Qobuz
« Reply #7 on: 14 Sep 2024, 01:00 am »
Qobuz doesn't provide Connect like Tidal and Spotify.
giordy60
Re: Qobuz
« Reply #8 on: 15 Sep 2024, 07:32 pm »
I know....but qobuz is testing a beta that allows the connect function on different devices....
rustydoglim
Re: Qobuz
« Reply #9 on: 16 Sep 2024, 03:45 pm »
I heard that Nuprime app is working for Qobuz again, so apparently this was some sort of integration problem between the streaming module supplier and Qobuz.
teggehifi
Re: Qobuz
« Reply #10 on: 17 Sep 2024, 07:22 am »
Indeed, it is working again. Thanks for your efforts! Much appreciated.
