To leave on, or to leave off. That is the question.
I have received a pre-amp. Since I like the the function of it (remote control), I swapped it with my existing one in the main system.   I took the existing pre-amp and put it as the office setup.
The main system gets shut off by a power center, so every thing gets shut off when not in use (which is good because of the turntable motor is always on). The existing pre-amp is a passive one, but it was modded with an active buffer (separate box with umbilical) that has no power switch. Should I add, at the very least, something to turn it off with (power strip)? Or, should I leave it on and not worry about it?
Should I sell it, and get something more user friendly?
2wo
Re: To leave on, or to leave off. That is the question.
« Reply #1 on: 29 Jan 2025, 12:32 am »
I am assuming that the buffer doesn't use a lot of power, if so just leave it on and be done with it. It will be fine.
Mr Peabody
« Reply #2 on: 4 May 2025, 08:23 pm »
I agree to leave it on.  If no power switch it was most likely designed that way.
