Cords for Dodd Buffer
0 Members and 1 Guest are viewing this topic. Read 3046 times.
HAL
Re: Cords for Dodd Buffer
« Reply #20 on: 22 Sep 2024, 12:59 am »
Well, I guess I blew the buffer as nothing lit up (tube included) with connection to the 12v battery.  The fuse is fine and I don't see anything untoward when I open the preamp but the next step is finding someone to repair this if possible.   Thank you all for your help as always.  Dave
If I remember correctly, the Dodd Buffer has a LM7806 TO220 case voltage regulator for the tube filament voltage for the 6H30 dual triode since it needs 6.3VDC.  Most likely this blew when the battery connections were reversed.  If the tube filament is not lit, then the buffer will not work.
There should also be a large diode at the grey Powercon 12V connector on the chassis for reverse voltage protection.
The buffer maybe fine, just the 7806 is bad.
DaveyK
« Reply #21 on: 22 Sep 2024, 01:20 am »
Thank you so much, Hal.    I am technically a novice but will see if I can give this a try.  With best wishes.  Dave
DaveyK
« Reply #22 on: 2 Oct 2024, 01:04 am »
Hey Guys,
  I replaced the diode on the powercon and it worked!  Worst solder job you have ever seen but so be it.   Thanks to all.  With best wishes.  Dave
