Print Screen W11 Pro
Don_S
« on: 24 Aug 2024, 07:52 pm »
I have searched with Google and all the suggestions do not work.
On my W10 computer there was a dedicated "print screen" key next to the "scroll lock" key. It worked without any problems. My new keyboard for W11 combines the print screen key with the F9 key. I have tried both print screen alone and with alt + print screen. When I go to the Microsoft Paint app there is never anything to paste.
Same results using the Windows key plus print screen.
I do not see an F-lock key on my computer. Where would it be? One suggestion said it might be engaged and I would need to press it again to disengage.
Some suggestions on Google mention a screenshots folder under pictures. I do not see one in the pictures folder.
Congratulations Microsoft for making something much more difficult than it used to be.
Re: Print Screen W11 Pro
« Reply #1 on: 24 Aug 2024, 08:13 pm »
Came back to W10 asap, there is much more bad news on W11 to come. I suspect Alt Ctr Del dont works on W11.
WGH
« Reply #2 on: 24 Aug 2024, 08:45 pm »
What keyboard? Is it on a laptop? The "Print Screen" key on my old IBM keyboard bring up the small Snipping Tool at the top of the screen.
You may be able to re-map the F9 key using Microsoft Power Toys Keyboard Manager
https://learn.microsoft.com/en-us/windows/powertoys/
I still use the free PrintKey 2000 v.5.10 but after 25 years it's getting a little buggy with W11. I exit and re-start when fails to start. I'm used to it so I swat the bugs and keep using it. No PrintKey 2000 doesn't open using the Print Screen button either.
http://www.oldversion.com/windows/printkey-2000-5-10
There are plenty of screen grab tools both free and paid.
 :scratch: Works for me.
« Reply #3 on: 24 Aug 2024, 09:46 pm »
There is some recipes on goo:
= Press the Windows logo key + Shift + S to get a static image cutout.
= Key Print Screen.
= Key Windows + Print Screen.
= Key Alt + Print Screen.
= Tool capture Windows + Shift + S
= Print with Xbox Game Bar.
Don_S
« Reply #4 on: 25 Aug 2024, 02:02 am »
Computer is an HP desktop. HP wired keyboard came with it.
« Reply #5 on: 25 Aug 2024, 02:15 am »
Thank you for informing us, I will not buy this brand.
Doublej
« Reply #6 on: 25 Aug 2024, 10:41 am »
Try holding down the fn key on the bottom left of the keyboard while simultaneously pressing the function key labeled prt sc . This might be be the f9 key.
If your keyboard has a button to the right of the f12 key that looks like a printer with a piece of paper, you can try pressing it to see if the screen prints.
Don_S
« Reply #7 on: 25 Aug 2024, 04:09 pm »
Doublej,
Thank you. fn+print screen worked. That never came up in any Google search.  :evil:Then I have to select full screen from a menu that appears at the top of my screen. That yields a message at the bottom right corner of my screen allowing me to "select here to mark up and share". That puts me into a window to save.
f8 is the key with the printer and paper icon on this keyboard.
The snipping tool is forced upon me when I do not want it. The menu where I select full screen has other options that do not seem to work. Another example of software that does so many things I do not want it is difficult to do what I do want. I think programmers sit around drinking red bull (or something else) looking for ways to justify their salaries. Or maybe they are just plain evil. :icon_twisted:
GentleBender
« Reply #8 on: 25 Aug 2024, 08:24 pm »
I use greenshot for screenshots. It is free and works well with Windows 11. YMMV, but you can tweak it to use another key if you’d like. https://getgreenshot.org/
Doublej
« Reply #9 on: 29 Aug 2024, 09:12 pm »
Doublej,
Perhaps it is time to abandon Windows in favor of Linux. I dual boot Windows and Zorin OS on an old Dell laptop and Zorin OS is looking pretty solid. Its faster than Windows on it.
« Reply #10 on: 29 Aug 2024, 10:20 pm »
Zorin can be a good option.
Meanwhile for us W10/11 mortals always keep your personal files backup up to date just in case this shit explode.
TX_Swann
« Reply #11 on: 6 Sep 2024, 02:44 pm »
I just use the keyboard shortcut "Win"+"shift"+"S"  to snip from my screens.
Don_S
« Reply #12 on: 6 Sep 2024, 03:11 pm »
Thanks for all the tips from everyone. I found my screenshots. Lots of them from my trials. For some reason a "screenshots" folder was set up under "pictures" for a different user. I never set up that user so I am terribly confused.  :scratch: I found the folder by using the search function at the bottom of my screen. The search bar I used is next to the Windows square.
Now I have to figure out how to get rid of that user and get everything back under my folders. This is a new desktop so something happened during setup. I am the only user. The user name is an abbreviated version of one of my gmail account names.  :scratch: :scratch: :scratch:
« Reply #13 on: 6 Sep 2024, 03:45 pm »
Maybe you could replace this hp keyboard for other with the usual printscreen key.
andy_c
« Reply #14 on: 6 Sep 2024, 11:44 pm »
For screen capture with Win11, I've been using the ancient IrfanView graphic file viewer.  I've been using that free software since the late '90s.  To do a screen capture, just fire up IrfanView and press the 'C' key.  You get a dialog asking what kind of capture you want to do. The choices are:
  • Full desktop area - all monitors
  • Desktop area - current monitor
  • Foreground window
  • Foreground window - client area
  • Custom rectangle/region capture
  • Object selected with the mouse
  • Fixed screen rectangle (allows entering screen coordinates)
After choosing the format and clicking Start on the dialog, IrfanView minimizes itself.  You press a hotkey to perform the capture itself.  The hotkey defaults to Ctrl+F11, which I always leave alone, but you can define it to be anything you want
It's an old-style Win32/Win64 program, so its use should be familiar.  You can save the captures to a whole lot of different graphics formats.  I use it extensively to do screen grabs to produce online software documentation.  It works fine under Win11.  Great graphics viewer too, with slideshow capability.  I also use it to do artwork maintenance for my music collection, like cropping and resizing.
