M1 Speaker Project ABC Switch testing
HAL
Re: M1 Speaker Project ABC Switch testing
« Reply #20 on: 18 Oct 2024, 11:04 am »
The AB demo is now setup for both the original and upgraded component passive crossovers.
All good, so waiting on the arrival of the other set of 4 XLR cables that match the first set of 4 to setup the dspNexus 2/8 as the DSP crossover instead of the passive crossovers for the C capability.  The ABC switching just needs the 4 amps outputs to run the speakers.
HAL
« Reply #21 on: 19 Oct 2024, 01:52 am »
Last set of 4 amp to speaker cables to connect the amps via the switches to direct drive the tweeter and woofer.   This is for the dspNexus 2/8 channels to amps acting as the new DSP crossover for the M1 speaker's tweeters and woofers.
HAL
« Reply #22 on: 21 Oct 2024, 01:48 am »
All the XLR cables arrived and installed to setup the DSP crossover for the ABC Switch from the dspNexus 2/8 and amps.  Wired the amps to the ABC Switch inputs for direct connection via the switch to the drivers.
Will be setting the same SPL for each crossover at 1KHz to have an equal comparison with band limited white noise.
Getting closer!
HAL
« Reply #23 on: 26 Oct 2024, 01:57 am »
The M1 Acoustic Suspension speakers ABC Switch System is operational and playing music.
Now to get it packed up for CAF2024 and work with the Magnepan LRS speakers.
