Anyone use the AlignmentProtractor dot Com protractors?
djpk
Wondering if anyone here has used the AlignmentProtractor dot com Arc Protractors. You can input the pivot to spindle distance, select the desired alignment and print off a protractor. I am most interested in anyone's experience with their AP alignment. It looks like an interesting alternative to the Lofgren B and Baerwald alignments.
S Clark
Re: Anyone use the AlignmentProtractor dot Com protractors?
« Reply #1 on: 8 Aug 2024, 01:35 am »
They are universally what I use.  I print one out for every tonearm I own.
nlitworld
« Reply #2 on: 10 Aug 2024, 03:24 am »
Yep, just recently used their custom arc settings for my Schiit Sol and it is perfect. Definitely a  :thumb: resource. I can't say I've had a reason to steer away from Baerwald settings, but it's nice to know there's options. I listen to a lot of 2xLP so only about half my albums have true inner grooves to maximize the AP setting.
