Small room sub strategy
0 Members and 1 Guest are viewing this topic. Read 4779 times.
listenermark
« on: 28 Jul 2024, 01:30 pm »
I have a budget of 600 dollars for a new subwoofer(s) in a small office system (10' x 11' w/ 8' ceilings, Emotiva integrated 50 watts a channel, Elac debut reference dbr2 monitors near field.) Should I go with a single 600 dollar sub (like the SVS sb1000) or two 300 dollar subs (like the RSL 10E.)  I am leaning towards dual RSL's as previous experience has taught me that room has really strange nodes.  What would you do and why?
BobM
Re: Small room sub strategy
« Reply #1 on: 28 Jul 2024, 11:28 pm »
Whichever way you go, try not to place the sub/subs in the corner. That's how you get evenb bigger room nodes. And raise them off the ground if you can by about a foot also. I know that's not "traditional" placement, but if you already have boom, this should certainly help.
nlitworld
« Reply #2 on: 29 Jul 2024, 01:50 am »
Vera-Fi Caldera 10 has been getting some reviews and would certainly fit the price point for a pair of them. Maybe as allowed, add a sheet of no-rez to the inside if you need to dampen the box a bit. And yes, boost the height, pull out into the room a bit and isolation footers will limit room modes.
Letitroll98
  • Too loud is just right
« Reply #3 on: 29 Jul 2024, 10:58 am »
Well the OP"s budget is over C&C guidelines, but nitiworld's suggestion of the Veri-fi sub at $199 looks very exciting.  So I'm going to leave the post here for a bit to see what develops.  If we get more C&C suggestions we'll keep it here.
jgladden36
« Reply #4 on: 8 Aug 2024, 06:29 pm »
The svs sb-1000 pro is $599 and superb. I used to have a set, they play nice in smaller rooms but have enough power to work well if you end up in a bigger room.
Letitroll98
« Reply #5 on: 9 Aug 2024, 09:30 am »
Okay then, off to Enclosures it goes.
