Nuprime DAC-8 reviews?
0 Members and 1 Guest are viewing this topic. Read 3406 times.
pjaizz
« on: 16 Jul 2024, 01:25 am »
Hey All:
I can't seem to find any reviews of the DAC-8 online.  Can anyone that has any experience with one post a review?  Considering one for use with a CDT-8 and an Oppo 93.  Thanks in advance.
rustydoglim
Re: Nuprime DAC-8 reviews?
« Reply #1 on: 18 Jul 2024, 10:02 pm »
DAC-8 will be a good match for your setup. It is an entry level DAC, so reviewers typically request for mid to high end models.
pjaizz
« Reply #2 on: 19 Jul 2024, 04:07 pm »
Thanks Jason.  I am using an IDA-6 currently, but I really want to try the I2S connection offered in the DAC -8. That aside, do you think the 8 would improve my sound over the IDA-6 DAC section (I have a small Parasound to replace the IDA amp section)?  I value transparency over anything else.
rustydoglim
« Reply #3 on: 29 Jul 2024, 05:11 pm »
Silent Angel Munich M1 is using the same DAC-8 design. That should give you some indication of the sound quality of DAC-8.
