VMPS Large Ribbon Center FST - $500- ATL - Price Drop
0 Members and 1 Guest are viewing this topic. Read 3383 times.
silverr1
This is one of the best center channel speakers ever made. Dialog clarity/intelligibility, bass extension, and overall transparency are all outstanding.
Note the drivers: A true ribbon tweeter, planar midrange and carbon fiber midwoofers -- you will have to spend over $2000 to get better sound from your center channel.
Specifications Bass:- 2x 16 cm (6") WCF megawoofer, front reflex loadedMid:- rectangular 10 x 20 cm (4 x 8") Neo ribbon, 280 Hz - 6.9 kHzTreble:- FST, 6.9kHz - 30kHzImpedance & Sensitivity:- 4 Ohm (3.6 min.) 90 dB/1W/1mPower handling:- 250 W rms / 4 Ohms, 20 W min.Frequency response:- 35 Hz - 25 kHz +0/-3 dBDimensions & Weight:- 27H x 82W x 33Dcm, 23 kg (10,5"H x 32"W x 13"D, 50 lbs)Output levels and distortion:- max. 1%THD fullrange/1W, max. 110+ dB SPL / 1 m
https://pointillistic.com/vmps-audio/HT-LRC.htm
« Last Edit: 26 Oct 2024, 09:50 pm by silverr1 »
silverr1
Re: VMPS Large Ribbon Center FST - $1000- ATL
« Reply #1 on: 4 Aug 2024, 05:43 pm »
bump
silverr1
Re: VMPS Large Ribbon Center FST - $850- ATL
« Reply #2 on: 23 Aug 2024, 12:41 pm »
Price drop
silverr1
Re: VMPS Large Ribbon Center FST - $700- ATL - Price Drop
« Reply #3 on: 15 Sep 2024, 10:43 am »
price drop
silverr1
Re: VMPS Large Ribbon Center FST - $650- ATL - Price Drop
« Reply #4 on: 28 Sep 2024, 12:04 pm »
Price drop
silverr1
Re: VMPS Large Ribbon Center FST - $600- ATL - Price Drop
« Reply #5 on: 11 Oct 2024, 10:37 pm »
Price drop
silverr1
Re: VMPS Large Ribbon Center FST - $500- ATL - Price Drop
« Reply #6 on: 26 Oct 2024, 09:50 pm »
Price drop
