VMPS RM40 - SOLD - ATL
0 Members and 1 Guest are viewing this topic. Read 3246 times.
silverr1
« on: 9 Jun 2024, 07:04 pm »
These are truly incredible sounding speakers, and incorporate the FST ribbon tweeters, which were a huge upgrade over the spiral ribbons in the Series 1's. These speaker’s won the best of show award at CES in 2002!
The cabinets are in very good condition, no blemishes on the motor boards, tops, edges or corners, only some faint scratches on two of the sides. All 14 speaker drivers, and the two passives are in perfect condition. These include all the optional upgrades from the factory including the TRT Caps!
Specifications Bass – 25 cm (10″) WCF Megawoofer bass, 25 cm (10″) WCF midbass, 25cm (10″) Passive Radiator Mid – four rectangular 10 x 20 cm (4 x 8″) Neo ribbons, 280 Hz – 6.9 kHz Treble –FST Ribbon 6.9 kHz – 30 kHz Impedance & Sensitivity – 4 Ohm (3.6 min.) 91 dB/1W/1m Power handling – 500 W rms / 4 Ohms, 20 W min. Frequency response – 24 Hz – 25 kHz +0/-3 dB Dimensions & Weight – 66″H x 13″W x 17″D cm, 240 lbs Output levels and distortion – max. 1% THD full range / 1W, max. 115+ dB SPL
For more information
https://pointillistic.com/vmps-audio/RM40.htm
https://classicalcandor.blogspot.com/2009/10/vmps-rm-40-loudspeakers-loudspeaker.html
https://hometheaterhifi.com/volume_12_1/vmps-ribbon-monitor-40-speakers-2-2005.html
Since these speakers are so large and heavy, I prefer local pickup in the Atlanta area. If you would like these shipped it would be at your cost for the actual packing and shipping fees.
Asking price is $1500 for the pair.
I also have the matching center channel which is even more rare than the tower speakers.
Large Ribbon Center FST
Specifications Bass:- 2x 16 cm (6") WCF megawoofer, front reflex loadedMid:- rectangular 10 x 20 cm (4 x 8") Neo ribbon, 280 Hz - 6.9 kHzTreble:- FST, 6.9kHz - 30kHzImpedance & Sensitivity:- 4 Ohm (3.6 min.) 90 dB/1W/1mPower handling:- 250 W rms / 4 Ohms, 20 W min.Frequency response:- 35 Hz - 25 kHz +0/-3 dBDimensions & Weight:- 27H x 82W x 33Dcm, 23 kg (10,5"H x 32"W x 13"D, 50 lbs)Output levels and distortion:- max. 1%THD fullrange/1W, max. 110+ dB SPL / 1 m
https://pointillistic.com/vmps-audio/HT-LRC.htm
Asking price for this $500
I’ll sell all 3 speakers for $1900
« Last Edit: 13 Jun 2024, 09:36 pm by silverr1 »
underdawg2024
Re: VMPS RM40 - $1500 - ATL
« Reply #1 on: 11 Jun 2024, 02:35 pm »
nice center channel wish I had 1 of those. I am long time member underdawg but lost my account. You can see my vmps I own in gallery id underdawg. This is my new handle which ill post the ones I use as mains now.
silverr1
« Reply #2 on: 11 Jun 2024, 05:02 pm »
Very nice setup, I definitely think you have room for at least 3 more speakers  :icon_lol:
