Ive read the mirco lines are extra sensitive to alignment and though very detailed, can be a bit on the thin sounding side.
Did you find the setup of the Goldring 1024 more difficult?
I see some manufacturers have high output MC versions as well. I might go that route as my Magnepan 1.7i s are hard to drive.
Amp is high current Odyessy Kismet, upgraded. Drives Maggies pretty good
Schitt Mani is just entry level so now I'm thinking price ratio may be way off for a $800 - $1k cart. Maybe MM with line contact stylus would be a better match for my system.
