ST10 had a loud crack...pop !!!
0 Members and 1 Guest are viewing this topic. Read 2563 times.
St10audiophiledac10
« on: 20 May 2024, 06:49 am »
Hello guys , new on here but recently I got my pre pro ST10 and DAC10 out from storage , carefully. And went through the process of connecting all needed cables and powered it up and a loud, very loud electrical pop and then a electrical smell, like burnt smell emitted from the sealed cabinet. I opened it up but could not see much wrong. After 15 minutes I decided to risk powering up again and it powered up fine and then I playedd some music through the unit and DAC10. Fine but something happened and was not good. Any ideas or help be grateful. Thinking of sending to John Ransley at totally wired, our local guru with Nuprime and other things musical.
Thoughts please before I do send it off.
Shane
John Casler
Re: ST10 had a loud crack...pop !!!
« Reply #1 on: 20 May 2024, 05:44 pm »
Hi,
If I had to guess, your description sounds like your initial effort had a "mis-wire".
I assume your unwired after the incident and then rewired after correctly.
That is the only thing I can think of initially.
