Benz Micro Reference specs
bratisalavstojkovic
  • Make some audio for personal use
« on: 7 May 2024, 09:28 am »
I have an old treasury Benz Micro Reference, 25+ years old, but without any documentation. Tried to search, no result, producer send me some old document and it says that recommended loading from 1.000 - 47k, which is strange, cannot be matched with mc step up, kind of difficult.
Does anyone have specification for Benz Micro Reference (without s, 2, 3, just plain)?
nlitworld
Re: Benz Micro Reference specs
« Reply #2 on: 7 May 2024, 02:25 pm »
Searching on Vinyl Engine, it shows internal impedance of 20 ohms, the cartridge likes to see >60 ohm load, and the output is 0.4mV. This should work just fine with a MC SUT. If you have a 1:10 SUT into a 47K input, try that. A 1:15 should be fine as well. If you have the ability to tweak loading resistors, try backing them down to 33K or even 25K with a 1:10 SUT. Benz Micro are weird on their "suggestion" of loading resistance where they really let you run wild to search for perfect values. All in all, this should work great with a SUT.
andyr
« Reply #3 on: 24 Jun 2024, 04:06 am »
That was the top Benz cart back then, right?
I had a Benz LP for nearly 15 years ... this had a coil impedance of 33 ohms.  My MC phono stage was not an MM phono stage with a SUT stuck on the front for a LOMC - as a result, I was able to experiment with a wide range of loading resistors.  I found 3300 ohms gave the best compromise between:
*  'airyness' of the sound stage, and
*  tight bass.
Higher than this and the bass started to lose tightness; kower than this ... the airyness started to disappear.
I would suggest getting hold of a phono stage which has, say, 64-66dB of gain and the ability to select 47K loading.  Then - using RCA 'T' connectors - you can experiment how different loading values affect the sound you hear.  (By putting a 'loaded' RCA plug into each 'T' connector, as well as the phono cable.)
Alternatively, if your phono stage has an MM option - allowing you to bypass the SUTs - try using an active 'head amp' (aka a 'pre-pre-amp') into the MM section instead of the SUT.
You simply won't hear the best the Reference has to offer, using a SUT.
