Raal 20XR now available
0 Members and 1 Guest are viewing this topic. Read 3134 times.
Wallacefl
« on: 5 May 2024, 02:20 pm »
The Raal 20 X-RAY is now available at Madisound. If possible I am willing to pay for a copy of the crossover between this tweeter and the Seas W18E001 (since I have a pair sitting around). Thank you.
S Clark
Re: Raal 20XR now available
« Reply #1 on: 6 May 2024, 01:14 am »
You should understand that it's not a two way interaction.  The box will be an equal player in the equation.
What you are asking is something like 2+ (8/x)= Y   It can't be solved without another variable being known.
Rshorb
« Reply #2 on: 9 May 2024, 11:30 am »
You would need to copy a current design by Salk. The only one I know is the HT1 -TL or HT2-TL . The 2nd option would need a second woofer. You can message me if you have any questions and if I can’t answer them I will call Jim.
WGH
« Reply #3 on: 9 May 2024, 02:26 pm »
And there are more!
The original HT1 is a smaller stand mounted ported speaker
https://www.salksound.com/model.php?model=Veracity+HT1
The original HT2 uses a slightly different RAAL tweeter in a ported design which preceded the transmission line model
https://www.salksound.com/model.php?model=Veracity%20HT2
The Veracity HT2C uses the exact same drivers as the HT2-TL in a smaller sealed cabinet. I use the HT2C as the center channel speaker with two HT2-TL speakers in my home theater. I consider the HT2C the perfect center channel speaker because dialog is always clear and easy to understand without any extra male voice chestiness. The speaker rolls off at 45 Hz but that doesn't matter in a home theater because surround processors begin rolling off low frequencies at 80 Hz sending bass to a sub. I use the 450w Van Alstine Vision SET 400 amp for the HT2-TL speakers and a rare AVA Insight 240/3 3-channel amp that has 125w/channel for the HT2C. A regular, affordable home theater receiver wouldn't have the power to drive the three front Salk speakers to acceptable home theater volume levels.
https://www.salksound.com/model.php?model=Veracity+HT2C
Wallacefl
« Reply #4 on: 9 May 2024, 07:50 pm »
Thank you for your responses. I am looking for the crossover for the last model of HT-1 which is a RAAL 20XR crossed to a SEAS W18E001.
jsalk
« Reply #5 on: 10 May 2024, 01:49 pm »
PM me.  We can build some crossover boards for you.
- Jim
Wallacefl
« Reply #6 on: 15 May 2024, 02:18 pm »
PM sent… cabinet will be vented 8*34*11(whd) from Parts Express.
Rocket
« Reply #7 on: 17 May 2024, 11:11 am »
Hi,
Boom! Jim is back even if its just a little bit. Great customer service :).
Cheers Rod
jsalk
« Reply #8 on: 17 May 2024, 02:34 pm »
That cabinet may be a bit too narrow.  The frame of the W18 will extend almost to the edge of the cabinet, so no round-over will be possible and you will be close to screwing the driver into the side walls.  Normally, a cabinet for the W18 will be 9" wide.
Also, you do not mention the port tuning frequency or port diameter.  So there is no way to determine if the cabinet is the right size for the W18 and whether the port is tuned correctly.
- Jim
Wallacefl
« Reply #9 on: 20 May 2024, 01:34 pm »
Thanks for the reply. I guess I may looking above my pay grade for a build and will let this go. Since the tweeter is no longer OEM are there any recommendations for using it in the future particularly crossing it higher with high roll off (example: approx 2600hz 4th order)?
jsalk
« Reply #10 on: 23 May 2024, 01:53 pm »
As long as you use a 4th order cross, you can use it from about 2kHz on up.  It will depend on what you are mating it with.  If you are using an accurate midrange that is flat beyond 2kHz, feel free to use a higher crossover frequency.
- Jim
