Audio Concepts Inc. Little V sub sat inputs/output connections.
opnly bafld
Owner opened it up and drew a diagram of x-o, looks like inner connections are input and outer connections are output. Makes sense, in = input;  out = output.
https://audiokarma.org/forums/index.php?threads/audio-concepts-inc-passive-sub-question.1058842/
Lin
« Last Edit: 2 May 2024, 04:06 pm by opnly bafld »
Capt. Z
Looking at the picture from the link you posted, you need to run your speaker cable from the amp to the sub on the 2 outer connectors. Then from the inner connectors of the sub to the satellite.
opnly bafld
Thanks for the input (pun intended  :wink: ).
