utilizing the 24 bit / 96 kHz feature on Toshiba DVD
0 Members and 1 Guest are viewing this topic. Read 1025 times.
CButterworth
Hello,
I have the Toshiba SD-3960 which boasts 24 bit / 196 KHz audio capabilities.  I have been using the digital out to a Art DIO DAC.
I like the sounds, even with an (as yet) unmodded Art DAC.  However, I would like to experiment with 24 bit / 96 KhZ recordings, by importing regular CD's into iTunes as regular (16/44) aiff's using error correction, then converting them to 24/96 aiff's using QuickTime 7.
Obviously, this dramatically increases the size of the audio files such that a 16/44 CD will not fit onto CD-R.
Is there a way of putting such 24/96 audio files onto a DVD-RW that would be readable by the Toshiba SD-3960?
Thank-you,
Charlie
