Groneberg Quattro Ref speaker cables - Upgrade or no?
0 Members and 1 Guest are viewing this topic. Read 3920 times.
Baemer
Hi Folks -
I have a set of Groneberg Quattro Refs that Klaus included with my Kismet Floorstanders (Thank you, Klaus and Irina!).  I have had some very good experience with some of the Audience cables formerly for speakers and currently for interconnects.  I am considering purchasing the Audiences to make this swap and check it out.  Anyone have any experience with this?  Knowing that the internal cabling is Groneberg, I'm wondering if my limited cash would be better spent elsewhere
I know Klaus uses Magnan's at his show to fantastic effect.....do we know if the Kismets at these show are wired internally with Groneberg or Magnan Cables?
Thanks for your input on this topic, hope all is otherwise well for you folks.
~B
JMW73
Re: Groneberg Quattro Ref speaker cables - Upgrade or no?
« Reply #1 on: 10 Apr 2024, 07:08 pm »
I believe they are wired internally with Groneberg.  I'd be inclined to save my money for something else.
Early B.
« Reply #2 on: 10 Apr 2024, 08:01 pm »
Sure. Experiment.
Baemer
« Reply #3 on: 11 Apr 2024, 01:07 am »
Hi Folks - Will reply back with updates.  Pulled the trigger today on some Au 24 se's today..
Best -
B
