L5/6 kit too much treble
0 Members and 2 Guests are viewing this topic. Read 26152 times.
CaptainBill
« on: 24 Mar 2024, 03:50 am »
Hi there,
I bought a Lampizator L5/6 kit DAC with WE and Telefunken tubes.  The treble is far higher output than other frequencies.  Any suggestions on how to balance this out without an equalizer?  Feeding it into a First Watt F5 amp and Elekit TU-8600S amp with same results.
Billy
Rusty Jefferson
Re: L5/6 kit too much treble
« Reply #1 on: 24 Mar 2024, 04:27 pm »
What's an 'L5/6 kit dac'?  I'm only familiar with L5 or L6 dacs (quite different) and didn't think there were any kit dacs? Exactly what type and brand of tubes are in the output stage, and what type/brand of rectifier is in the power supply? And is there a plate on the back you can post a picture of?
CaptainBill
« Reply #2 on: 24 Mar 2024, 04:47 pm »
Sure thing, let me figure out how to post pics.
CaptainBill
« Reply #3 on: 24 Mar 2024, 05:21 pm »
Telefunken AU7 x2
6DJ8 but using WE 396A
Bendix 5852
CaptainBill
« Reply #4 on: 24 Mar 2024, 05:24 pm »
CaptainBill
« Reply #5 on: 24 Mar 2024, 05:29 pm »
Rusty Jefferson
« Reply #6 on: 24 Mar 2024, 05:52 pm »
Well, I've never seen one of these before.  :D  Perhaps the Lampi crew will chime in.
I can tell you the WE 396A is not a drop in replacement for 6DJ8 though I've heard of people doing that with an adapter, but they still aren't that similar. You might want want to try some standard 6DJ8/6922 to start, maybe Mullard, but anything you have to get going . Assuming the Telefunken are in the 12AU7 slot, those are going to be more clear and open on top compared to say a Mullard or Amperex 12AU7. Can't tell what rectifier is in there (GZ-34?), but there's probably a Mullard for that too!
CaptainBill
« Reply #7 on: 24 Mar 2024, 06:58 pm »
That’s the Bendix 5852 rectifier. The WE tubes have an adapter base.
Gopher
« Reply #8 on: 21 Apr 2025, 02:34 pm »
I have no idea what this is, but LampizatOr hasn't sold kit anything in many years.   My guess is this is some knock off from an eBay seller in China.
I.Greyhound Fan
« Reply #9 on: 21 Apr 2025, 03:48 pm »
Change the tubes and/or the output caps.  I built a Pass Labs B1 preamp/buffer and played around with different caps and resistors.  It was eye opening in the least to hear the differences.  I found that Clarity Caps had less treble energy.
Check this site out-
https://www.humblehomemadehifi.com/Cap.html
CaptainBill
« Reply #10 on: 21 Apr 2025, 04:41 pm »
Thank you, will do.
I.Greyhound Fan
« Reply #11 on: 21 Apr 2025, 08:14 pm »
I would also replace those sand cast resistors with Mills or something similar.
CaptainBill
« Reply #12 on: 1 Sep 2025, 02:49 am »
I swapped out all my tubes and it sounds great.  Swapped in all the original tubes but am still using an alternate rectifier tube.  Also sounds great.  This is a really good DAC!
