Bryston Bi-200 New Integrated
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Bi-200 New Integrated
« Reply #100 on: 19 May 2025, 12:29 pm »
« Reply #101 on: 11 Jun 2025, 11:22 am »
mr_bill
« Reply #102 on: 3 Jul 2025, 09:09 pm »
James any plans or updates on adding the digital option to the BI 200?
« Reply #103 on: 4 Jul 2025, 03:00 am »
Hi Bill - no plans currently.
Most seem to want to keep it as a purely analog unit.
james
« Reply #104 on: 4 Jul 2025, 03:13 pm »
elfrigo
« Reply #105 on: 23 Jun 2026, 03:49 pm »
@James Tanner - a very nice (sounding) amp.
I order to make live easier - can you provide information on the RS232 protocol of the Bi-200?
Also what the plug should be in order to be able to trigger the Bryston to turn on?
Same for the USB control - what do you need to use this to control the Bryston?
elfrigo
« Reply #106 on: 25 Jun 2026, 11:13 am »
On additional question - the LAN interface goes to a webpage where you can use a virtual remote to control the Bi-200. Does the LAN provide any API interface so I can use web-calls in my home-automation to control this amp? If so, are you willing to share?
VKB
« Reply #107 on: 9 Jul 2026, 03:14 am »
Hello All,
I recently received a new Bryston Bi-200 and I am really enjoying the sound so far.  I look forward to getting to know the features.  The sound is really clean.
VKB
« Reply #108 on: 9 Jul 2026, 03:20 am »
After receiving my Bryston Bi-200, I tried to register my product on the website.  I did not find the Bi-200 listed in the drop down menu.  I phoned Bryston and was told that the site was not updated yet, and that I should check in this forum to find out when I can register my product for the warranty.
« Reply #109 on: 10 Jul 2026, 10:46 am »
Hi VKB - you do not have to register - just keep your bill of sale.  :thumb:
best
james
