Building a Kegger SEUL EL34 Amp
0 Members and 1 Guest are viewing this topic. Read 6041 times.
Presb4
Re: Building a Kegger SEUL EL34 Amp
« Reply #20 on: 19 May 2024, 10:23 pm »
I'm not sure what the bobin material is. The OPT should be around 6 to 8 watts greater than I need so i'm sure it will be fine. Now that summer is in full swing, I will have some time to finish this project over the next couple months.
« Reply #21 on: 19 May 2024, 10:46 pm »
If your speakers are hi sensitivity as 100dB 8Ω or 16Ω, six watts of SET bliss are sufice to shake windows, UL are suited only to guitar amps due the extra distortion, IMO. There is an good example in the Decware Rachel EL34SE.
