VPI Super Prime Scout 21 Turntable w/ 10.5" Tonearm & VTA On the Fly 2800 SOLD
0 Members and 1 Guest are viewing this topic. Read 968 times.
hoard
SOLD This was bought at Upscale, The Super Scout 21 is an amazing turntable. Look at any VPI turntable as the sum of parts. The plinth, tonearm, tonearm base, motor, platter, and feet, look at this as a Prime Scout or Scout II, with the following options INCLUDED!
Instead of the much cheaper 9” arm and lower end base, this has the upgraded 10.5” JMW-10 aluminum tonearm, you get a longer tonearm with better tracking, also included VPI's VTA on-the-fly tonearm base! This means that you can fine-tune VTA while you listen, which is critical to eliminate top end sibilance. The tonearm and base by themselves are $2200!!
Upgraded 20-pound platter you find on the Prime and Classic series
upgrade VPI Deluxe Delrin/stainless steel screw-down record clamp and the HW-40 Reference Isolation Feet.
Blue Point Special EVO III moving-coil cartridge
Can ship to Cont USA for 150.00 with insurance
This will be shipped in the original, multi compartment foam and double boxed as the table was originally shipped from the factory,
with all the original paper work, as new.
« Last Edit: 7 Jun 2024, 06:14 pm by hoard »
