RM30 Series II upgrade Passive
0 Members and 1 Guest are viewing this topic. Read 1211 times.
tbrooke
« on: 23 Feb 2024, 12:33 pm »
Finally getting around to the Series II Passive and I found this 10 inch Passive and wanted to make sure it is the right one:
https://www.css-audio.com/online-store/CSS-APR10-10-Passive-Radiator-p148179575
Looks like a good price
GeorgeAb
Re: RM30 Series II upgrade Passive
« Reply #1 on: 24 Feb 2024, 12:55 am »
That's the one. I recall having to trim a bit of the edge of the included gasket for fitment. Seven washers was my sweet spot per my recollection, its been awhile. Greg username G E did a really nice job on providing a guide for the entire process.
G E
« Reply #2 on: 25 Feb 2024, 10:37 pm »
I found it easiest to remove the plastic or hard rubber gasket from the passive. It was then a perfect fit in my opening.
Be sure to use some gasket material if you remove it. I used 3M product that is intended for automotive use. Never hardens, not a glue. Refer to my write up for its name etc.
Good luck!
« Last Edit: 2 Mar 2024, 11:25 pm by G E »
