0 Members and 1 Guest are viewing this topic. Read 18373 times.
If you go by Mardis' site (and he's played with these more than almost anyone), the Super T pretty much solves the bass issue. The bass issue is mostly down to PS inadequacy. And a bass shy amp will be thin-sounding.
Quote from: SarchiIf you go by Mardis' site (and he's played with these more than almost anyone), the Super T pretty much solves the bass issue. The bass issue is mostly down to PS inadequacy. And a bass shy amp will be thin-sounding. That's good to hear. I'm not paying $130 for an amp that is RIGHT on the cusp of being too little power for my needs though. I'd rather upgrade the cheapie one and see if I hear improvements.
no one has mentioned using a tube pre amp with the t-amp. This totally removes any nasally thin, harsh, and fatigueing qualities from the sound, adding depth and roundness while still maintaining the clarity, crispness and speed. I didn't like the t-amp that much overall (due to brightness) until I hooked up my Luxman LX-33 as a pre-amp. I just max the volume on the t-amp and use the volume control on the Luxman.
Do you think tube preamps "fix" T-amp problems or just mask them by perhaps being rolled off and less detailed. I know not ALL tubes are rolled off, but SOME are.
