GRS 10SW-4 10 Box Configuration
0 Members and 1 Guest are viewing this topic. Read 3417 times.
JCarney
« on: 10 Feb 2024, 06:54 pm »
I have a GRS 10SW-4 10" driver I would like to put in a 1.25cuft vented enclosure as recommended by PE. I cannot find anything more on the enclosure other than the volume. My question is there are a couple of general sets of plans for what seems to be a generic 10" driver that I have found for both sealed and vented, but I'm not sure how to proceed. Would a generic plan just be a waste of time? Do I go ahead and do the 1.0cuft sealed enclosure? I do have more, but I'll wait to see if I get lucky and someone has worked with this driver. I'll include a link to PE for the driver specs, just scroll down past the description. I have a Dayton 100w digital plate amp to drive it.
JCarney
https://www.parts-express.com/GRS-10SW-4-10-Poly-Cone-Subwoofer-4-Ohm-292-482?quantity=1
hdspeakerman
Re: GRS 10SW-4 10 Box Configuration
« Reply #1 on: 13 Feb 2024, 08:27 pm »
You might do better on PE forum.
JCarney
« Reply #2 on: 13 Feb 2024, 10:07 pm »
Thanks hd, good idea.
JCarney
JCarney
« Reply #3 on: 13 Feb 2024, 10:31 pm »
I registered at PE for the forums. I cannot figure out how to post a new topic. I looked at the help section and it said I may need special permission for my first post. How does on go about getting said permission. Not at all easy to navigate.
JCarney
hdspeakerman
« Reply #4 on: 14 Feb 2024, 03:33 am »
At the bottom of the PE forum page is a "Contact us"  box.  Click on it and then put you questions in the box and they will answer.
JCarney
« Reply #5 on: 14 Feb 2024, 05:02 am »
Thank You again hd, I did as you suggested and await a response I'm guessing tomorrow since I did just a bit ago.
JCarney
