Solid State or Tubes with your NX-series speakers?
0 Members and 9 Guests are viewing this topic. Read 240140 times.
jmimac351
Re: Solid State or Tubes with your NX-series speakers?
« Reply #360 on: 11 Oct 2025, 02:21 pm »
« Last Edit: 5 Dec 2025, 06:57 pm by jmimac351 »
mkrawcz
« Reply #361 on: 11 Oct 2025, 02:51 pm »
mkrawcz, you have a nice little collection of amps, (mostly class A?), I’d be interested in a little pros/cons comparison 😇😎. Also, what are you listening on?
I listen on NX-Oticas, NX-Studios, NX-Bravos, NX-Bravo Towers, Superminis, Brutes, upgraded Magnepan LRS+, Caladans, and modded Sony sscs5 mostly. I have a number of other speakers, but they sit unused most of the time(probably time to start cleaning house). I have somewhere around 30 amps with an equal split of tube, class A, AB, and D. My general preference is  Tube and Class A. They sound more convincingly real and natural. The closest class d amps I have that knock at the door are probably the Hypex Nilai and NCx500 amps, they soften the edges just a bit more than the Purifi amps making them a little less “etched”. The funny thing is that the Douk Audio A5 with upgraded opamps is really close to those amps at a fraction of the price. The Pass First Watt amps tend to be the closest Class A amps to really good tube amps but without the expense of constantly buying tubes which is why I prefer them overall. The thing I have found is there is no perfect amp for all types of music which is why I rotate around constantly. Tubes and Class A for jazz and classical, class D for rock.
mkrawcz
« Reply #362 on: 11 Oct 2025, 02:56 pm »
I was going to ask if you did that.  I saw mention of that improving it.  So far I have been able to resist buying one.  And then I start rationalizing the nice case and how that is worth money by itself.   :D
I think these are the output transistors in it.  Bipolar.
Does it sound like it is putting out 20w/ch into 8ohm?
https://www.digikey.com/en/products/detail/onsemi/MJL21193/606091
It actually sounds a lot more powerful than 20 watts. I see it’s now $250 on Amazon, totally worth it. I will have to dig into it and figure out some stuff to tweak, I almost don’t want to mess with it too much beyond replacing the wiring and binding posts.
nlitworld
« Reply #363 on: 11 Oct 2025, 03:37 pm »
Just got this little 20 watt class A amp that is allegedly a clone of the Musical Fidelity A1 without the preamp section. BRZHifi A1S, cost $225 on Amazon and I am shocked at how good it is.
I don't need a new amp... I don't need a new amp... If I say it enough times, I'll start believing it, right? I've seen this one before but never thought to jump on it. I haven't yet owned a pure class A ss amp, and an affordable (and tweakable) option such as this could be a fun little piece. After I finish my other amp projects (tubes4hifi ST35 and more Douk A5 mods & custom case) I may give this a go.  :thumb:
goggle1824
« Reply #364 on: 11 Oct 2025, 04:10 pm »
Awesome, thanks so much for sharing your thoughts and experiences on all of this, this summary is exactly what I was hoping for! 🍻🙌🏼
Given your amps experience, I’m curious, have you heard a FW Aleph J or a good version of the DIY version?
BrandonB
« Reply #365 on: 11 Oct 2025, 05:06 pm »
Sounds like you need a new amp!
BrandonB
« Reply #366 on: 11 Oct 2025, 05:19 pm »
Not touching source components, yet. I am very happy with my source gear and happy with the money I have in it.
I recall you had a full lineup of Ayre.  What is your current setup including your source gear?
NXSTUDIO-DRUMMER
« Reply #367 on: 11 Oct 2025, 05:33 pm »
Just got this little 20 watt class A amp that is allegedly a clone of the Musical Fidelity A1 without the preamp section. BRZHifi A1S, cost $225 on Amazon and I am shocked at how good it is. This beats all the cheap class D amps you will find on Amazon by a mile. I see some opportunity to tweak also. Playing it through the NX-Bravo Towers and it’s very much a high end sounding Class A amp. Still can’t believe this cost so little. Just the chassis alone is something that would cost about $200 for DIY.
I'm curiouos how much better does this amp sound compared to a $80 Douk Audio A5 for sale on Amazon?
One would hope it sounds better, since it over 2 1/2 times the cost of the A5. Question is how much better though?  By far it looks more impressive, literally in all categories IMHO. It would be interesting to compare both heads up. I've invested $59.00 in upgrades on my A5, upgraded the op amps , added a Acopian 48 volt / 8 1/2 amp linear supply, $130.00 total, including the A5 purchase. Even so, it's still less than $225.00 with upgrades, making this mini amp pretty impressive sounding for the price too. Playing the A5 through the NX-Studio's, or my Mordaunt Short speakers is damn impressive, for what I've invested.
I can't imagine the A1S is that much better? If it is, without doubt it's a best kept secret. For obvious reasons, you can't compare in terms of power, hands down my A5 is more substancial, with a 26lb acopian regulated linear power supply providing over 300 watts cllean watts. Compairing the circuit designs, laughable, the A1S is more impressive. I wish someone owned both to do a real heads up comparison.
Even my other Acopian LPS below does a hell of a job too.
mkrawcz
« Reply #368 on: 11 Oct 2025, 06:01 pm »
I have the Douk A5. One isn’t necessarily better than the other. The Douk A5 is more neutral with precision pinpoint imaging and instrument placement. The A1S is more about the vivid midrange that comes from 2nd harmonic distortion. Once you hear it, it’s hard to not continue wanting it. It’s why people like tube amps so much. That distortion profile makes vocals and orchestral instruments sound more real like they’re actually in the room and not a recording.
NXSTUDIO-DRUMMER
« Reply #369 on: 11 Oct 2025, 06:22 pm »
Refreshing to know one has both amps, providing us an evaluation. Thanks for you input, distinguishing the differences between the two amp's characteristics. The feedback you've contributed, will certainly help others in the marketplace shopping around.
I will say this regarding the A5, one is truly missing out not using the A5 connected up with a tube preamp. It helps it deliver what you described,
"makes vocals and orchestral instruments sound more real like they’re actually in the room and not a recording."
Note:
If your not planning on using a preamplifier with an A5, At least upgrade the attenuator, with a higher quality one. The stock one does degrade the signal somewhat. Using a nice tube preamp connected however, one should position the setting on the A5 to full volume. Now your preamp's attenuator will adust the volume, bypassing the A5's attenuator, eleviates signal degradation.
« Last Edit: 11 Oct 2025, 10:32 pm by NXSTUDIO-DRUMMER »
jmimac351
« Reply #370 on: 14 Oct 2025, 01:41 am »
Huskerbryce
« Reply #371 on: 14 Oct 2025, 03:21 am »
170db??   Do you have an Imersiv D1 DAC??  I want to hear one.
jmimac351
« Reply #372 on: 16 Oct 2025, 12:45 am »
Huskerbryce
« Reply #373 on: 16 Oct 2025, 03:02 am »
Yes, I’ve spent a lot of money on a lot of equipment over the years, trying to achieve audio Nirvana. All of it was only to find that it kinda all sounded the same. The first moment of audio Bliss that I had was when I took the plunge and built a pair of Danny‘s NX Otica speakers. Suddenly, I was wowed by the cost to sound ratio. I was listening to music that I was intimately familiar with and it sounded way beyond my past threshold of wow.   My multi thousand dollar mono blocks came alive. I was about ready to sell them off. I think there is a value to some things in the audio world and I’ve listened to many different digital to analog converters claiming to be the “it” factor.  Most were meh….That left much to be desired. So I am skeptical about the new $12k imersiv…   Hoping you buy one so I can get an idea of what its all about
Craig Young
« Reply #374 on: 16 Oct 2025, 04:41 am »
My current preamp and amp is going to be accompanied by AGD and Aric. I am currently listening to Roon via Schiit Freya+ to Aegir. I am getting AGD Duets to run with my Freya+. In the near future I am planning on getting Aric Motherlode XL and which tier?
BrandonB
« Reply #375 on: 16 Oct 2025, 07:34 pm »
It's obvious that what jumps out is that they say how incredible it is, "never heard anything like it"... OVER THE TOP comments. And they go on and on and on.
THAT is why I want to hear that DAC. It's very likely to be very different.  And I think because so much stuff sounds the same, people keep buying and selling in search of "IT", only to hear the same old thing again... that the YouTube guy said was "IT".
I read some articles last night about this DAC and was  intrigued.  I don't understand all the science but I could follow along with some of it out.  I posted about it in a few forum's and people acted like "ah I've seen that old thing before and all kinds of DAC's have more than one chip".  I guess people only process half of what they read....lol  Have you spoke to anyone about it in person?
jmimac351
« Reply #376 on: 18 Oct 2025, 02:57 pm »
jmimac351
« Reply #377 on: 18 Oct 2025, 04:57 pm »
« Last Edit: 5 Dec 2025, 06:58 pm by jmimac351 »
Huskerbryce
« Reply #378 on: 19 Oct 2025, 02:23 am »
I was listening to a Vfet just this afternoon.  Broke it out and dusted it off at a friends place.  Hooked it up to a pair of B&W 803s.  Sounded really good.  The only downfall was when you increase the volume past “normal” on really dynamic tracks.  Fun little amplifier.
jmimac351
« Reply #379 on: 19 Oct 2025, 02:38 am »
