0 Members and 1 Guest are viewing this topic. Read 8559 times.
Are those Klipsch speaker? If so they are notorious for sounding terrible in large echoey spaces. I hope you are not in love with them. The money spent on room treatments would be better spent on different speakers, either open baffle that work best in large open spaces (Magnapan) or a speaker with a more focused presentation. Speakers with a RAAL tweeter don't have as much a wide dispersion as a dome tweeter. The big, flabby, phat, slow passive radiator on the back of the speaker isn't doing you any favors either.
And the slap echo is very real in here. I can hear it even when speaking. In addition to the glass, the tall ceiling and wide walls results in lots of sq footage of hard blank wall space. So I am convinced that absorption and dampening are required.
I recently dealt with a similar issue, although in a smaller room with large windows covering three sides, a sloped ceiling, and a stone tile floor. I did two things to eliminate the echo -- I purchased sound barrier curtains and got a rug to cover nearly the entire floor. https://www.amazon.com/gp/product/B08V8JBDZ1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1You can spend thousands experimenting with acoustic treatment. At the end of the day, you've got a tough room to tame and it may sound lousy no matter what you try to do, so spend your money wisely. I agree with WGH about acquiring a set of open baffle speakers. This purchase will solve 58% of your problems.
I don't think those Klipsch can be tamed, there is a limit to the amount of panels a partner will tolerate. Are you single? Put in too many panels and you will never make it to the second date.It's both the highs and bass bouncing around. I'm thinking Fritz Carbon 7 speakers, they are not as detailed as his Carrerra's, the highs are very well controlled and won't drive you out of the room. I have a pair of Carbon 7s on long term loan, so far our audio club has heard them in four rooms and they have sounded excellent every time, we love them. The Carbon 7s can be driven by a 2.5w amp too.Bass in your room has to start and stop on a dime to control room reflections. The Klipsch woofers are still making noise long after the note has stopped. A pair of REL woofers will be super fast plus they can be located where they sound the best. Don't get the biggest, the lowest notes will overwhelm your room. A pair of T/9x with the 10" driver would work.Once you have the speakers and sub decided on, then you can work on room corrections. Until then you have no point of reference. Right now adding a lot of absorption would like be trying to make a pair of chain saws sound great.
I’d spend money on thick carpet, heavy drapes and room treatments instead of new speakers. The problem is the room.
Rockwool is not designed for music, it’s an insulation. It may work a bit, but it works badly so why bother with it.
Tyson is entirely correct. Chasing a speaker to tame the room is a mistake. Get the room sorted out first and you'll be amazed. And YOU are entirely correct that Rockwool is and excellent acoustic absorber. Rigid fiberglass and bonded logic recycled denim are also excellent and readily available.Thin wall hangings and thin carpets are only minimally effective. They might tame the top couple of octaves, but do nothing at midrange frequencies. Start at the window wall. Purchase heavy velvet or sound absorbing curtains. I personally do two sets back to back. I've got a wall of windows to my right side as well. A triple slider. Try the windows first and see how much improvement you get. Walk into the room, close your eyes and ask yourself if you can still easily hear the sound of the room. You want to get yourself to a point that it sounds neutral. Like you can't tell how big the room is, but not so far that it sounds muffled and dead. If that's not enough, maybe go for the back wall since your couch is up against that wall. Again, a thin carpet or tapestry is not good enough. Minimal 2" thick material back there. I used a thick wool rug screwed to a wood frame holding 2" bonded logic. Greg You could also call GIK for recommendations if the diy route is not your thing.
I will use either Owens Corning 703 (or 705), or one of the Rockwool / Roxul variants. I plan to fabric wrap the front andrear in the traditional way.
I think you would be far better off skipping the fiberglass or Rockwool insulation and consider the panels at acoustic fields.com. You might want to watch, or consult with, Acoustic Fields.com, they are on YouTube. Their solution might not be so waf friendly though. I am in the same boat. Will use window coverings and live with it. Rocket Ronny
12' wide wall of glass, RIGHT side:- Very tall ceiling, slopes from RIGHT to LEFT, 9 to 15 ft.- Back wall to ears is 2 ft (unfortunate, but unavoidable)- Left Speaker: open layout to the left, front wall ends at left edge of speaker cabinetSlap echo is creating serious discord in the sound and very rapid listener fatigue,to the point of unlistenable.I will use either Owens Corning 703 (or 705), or one of the Rockwool / Roxul variants. I plan to fabric wrap the front andrear in the traditional way.
