Source for airplay / Belkin soundform replacement for better quality
0 Members and 1 Guest are viewing this topic. Read 13324 times.
[email protected]
Hi community! I stream music trough a Belkin soundform connect with apple music. I made a test to compare this Belkin to a direct connection from my iphone 15 usb-c to my dac, Chord mojo2.
I was impressed with the better sound quality from my Iphone connection.
Any recommendations to improve/replace streamer sound quality?
Here the ideas i have but would like to hear what you have and if you made any comparaison tests:
- Chord Poly but a bit on the expensive side
- Wiim mini
- Allo digione signature player
- Bluesound
- does a IFI ipurifier2 could improove the belkin?
Many thanks!!!
My gear: Iotavx SA3 amp, XSLS Encore speakers.
« Last Edit: 7 Jan 2024, 02:03 pm by [email protected] »
Doublej
If you decide to go down the WiiM path, I would get a Pro which has PEQ, has more horsepower behind it, and can be an airplay casting device.
Comparison of WiiM models at the bottom of this page: https://wiimhome.com/wiimpro/overview
Another option is Eversolo.
[email protected]
I found my problem and sharing it so other peoples can benefit. Belkin soundform connect have settings accessible trough the app (appstore). Volume has to be at max. Iphone volume also have to be at max. I am guessing that digital volume controls induce some kind of noise in the signal. Also, sound quality improves when i power the soundform connect by a battery.
Mat9
If you have the mojo then poly is a no brainer, allows you to take your library outside with you and some basic streaming services (upnp & online radio)
If those things are not important I would probably choose the Bluesound nano with a nice power supply.
