X-Voce revision and performance update?
0 Members and 1 Guest are viewing this topic. Read 10755 times.
jmimac351
Re: X-Voce revision and performance update?
« Reply #40 on: 7 Jan 2024, 03:29 am »
I have both an X-Voce and a pair of X-Statics based on the original AV123s, both with hands-on upgrades by the Skiing Ninja himself.   I'd be real curious what could be upgraded beyond this.   I've had them running for almost three years now in my home theater setup, and they are still going strong and sound fantastic.    :thumb:
Sometimes being content can be a real challenge, but it's a Blessing when you find it.  If you're happy, I'd suggest being careful about allowing other's opinions to cause you to redefine your measure of YOUR happiness.  There's always gonna be some other rabbit to chase, if distracted by it.
Vince in TX
« Reply #41 on: 7 Jan 2024, 04:13 am »
Well, I'm a computer engineer and a performance automotive enthusiast aside from being a cinephile and fledgling audiophile.  "Content" is not even in my vocabulary.   I'm always tweaking stuff.  I just got done upgrading two gaming PCs and ordered new modern headlights and infotainment system for my Corvette.  It's just my nature as an engineer to constantly have things in flux.   But I do appreciate your insight.    :D
jmimac351
« Reply #42 on: 7 Jan 2024, 04:50 am »
And there ya go... that's YOUR fun; however, you may be doomed.  :lol:  :thumb:
ThomasGuitars
« Reply #43 on: 8 Jan 2024, 12:40 am »
Vince in TX  What do you have around your tweeters?
jmimac351
« Reply #44 on: 8 Jan 2024, 12:53 am »
Looks like this? Checkout the speaker!
@Vince... let me know if you're doing that.  There's something I can share with you that you may be interested in.  You'll need to do some measurement and I can show you an example.
https://audiophilereview.com/affordable-speakers/diffraction-be-gone-rocks/
https://audiophilereview.com/affordable-speakers/a-springtime-switcheroo-and-an-x-static-value/
Vince in TX
« Reply #45 on: 8 Jan 2024, 03:37 pm »
Yes, that's exactly what it is, and these are those exact speakers that Steven owned.   These speakers came to me second-hand, so all of these changes and updates were done while in his possession (Steven Stone).   Steven is on here (or at least he was at the time):  https://www.audiocircle.com/index.php?topic=61602.msg628580#msg628580
« Last Edit: 8 Jan 2024, 04:54 pm by Vince in TX »
Danny Richie
« Reply #46 on: 8 Jan 2024, 04:15 pm »
The latest tweak overlaps the lower drivers a little more and increases mid-bass output that was being affected by the floor reflection.
Vince in TX
« Reply #47 on: 8 Jan 2024, 04:52 pm »
Interesting.   So if I have a carpeted floor, there should be no impact, correct?
Hobbsmeerkat
« Reply #48 on: 8 Jan 2024, 07:20 pm »
You will still have the reflection as carpet isn't thick enough to be effective at damping frequencies in the mid-bass region.
rasykora
    • Sykora Sound Technologies
« Reply #49 on: 8 Jan 2024, 09:51 pm »
Floor reflection frequency is dependent on speaker height, listening distance and height.
See here: https://mehlau.net/audio/floorbounce/
jmimac351
« Reply #50 on: 8 Jan 2024, 10:16 pm »
Vince, if you peek at the info about my Wilson Audio Duette, you'll see mention of the foam / circular cutout on the front baffle and the commentary about the raised circle causing a bit of ripple in the upper response.  I have not played with making that transition different, yet.  I have no idea if the felt you have around your tweeters and the "circle" is causing a similar issue on yours.  Just thought I'd share in case it's of interest / helpful.
Have Fun.
https://www.audiocircle.com/index.php?topic=187454.20
« Last Edit: 9 Jan 2024, 12:17 am by jmimac351 »
rasykora
« Reply #51 on: 9 Jan 2024, 03:20 pm »
So, as i posted earlier, floor bounce frequency is dependent on various distances.  I have an average sort of family room for my home theater.  The center speaker is just under my flat screen and I sit on a leather couch about 10 feet away. Let's plug these distances into the floor bounce calculator and see what we get...
So for my listening situation, would expect a primary null just under 400 Hz. If you sit further away, the null goes up in frequency further.
Anyone else have a much different listening arrangement?
« Last Edit: 9 Jan 2024, 05:17 pm by rasykora »
Vince in TX
« Reply #52 on: 12 Jan 2024, 03:58 am »
:green:
Noted.  I'll check it out.   Although there is carpet, rug, thick carpet pad, and 1/8" thick vibration dampening rubber mat under there.    :green:
rasykora
« Reply #53 on: 15 Jan 2024, 12:53 am »
How many channels is your new home theater and are you doing height speakers?
Vince in TX
« Reply #54 on: 15 Jan 2024, 03:31 am »
Are you talking about mine?   13 speakers and four subs (7.4.6 ATMOS), two of which are the Double Troubles and two sealed subs - one at the front and one at the back.  Four of the surrounds are GR X-On Walls.  Probably overkill for a 15' x 20' room, but ATMOS movies like Dune, Ready Player One, Blade Runner 2049 are incredibly immersive.  I'm watching The Pacific on Netflix right now (it was on HBO), and the action scenes with gun fire and explosions are unbelievable.
Of course, high definition stereo music sounds pretty good, too.    :thumb:
rasykora
« Reply #55 on: 16 Jan 2024, 01:59 pm »
Yes, thanks. Your newer pic appears to be in an upstairs attic.
Was wondering how you determined speaker positions and how high is your ceiling?
Vince in TX
« Reply #56 on: 16 Jan 2024, 09:26 pm »
It's a 9' ceiling, and I used the free 3D design tool at Audio Advice to rough it in and determine the best screen size and viewing distance for maximum immersion.  I have two rows of seats.  You can see the X-On Walls in this photo.  For overhead speaker placement, the best resource is Dolby themselves:  https://www.dolby.com/about/support/guide/speaker-setup-guides/
rasykora
« Reply #57 on: 18 Jan 2024, 12:42 pm »
Thanks again. Did not realize you had completed it as thought the empty room pic was more recent.
What drove you to 4 subwoofers and are you planning any room treatment?
Vince in TX
« Reply #58 on: 18 Jan 2024, 09:58 pm »
Bump this thread if you want to chat about stuff in the forums since we are way off topic here:  https://www.audiocircle.com/index.php?topic=175957.msg1854732#msg1854732
Theater details:  https://www.audiocircle.com/index.php?topic=53699.msg1875304#msg1875304
rasykora
« Reply #59 on: 18 Jan 2024, 10:40 pm »
Thanks for sharing and will post off topic questions there once I take it all in.
As for this thread, did you get the latest upgrades for your X-series fronts?
