Balanced tonearm leads (I'm new, so I can't use the search engine.)
0 Members and 1 Guest are viewing this topic. Read 3024 times.
saab_oteur
Can anyone recommend a shop that can solder xlr/balanced cables on a Rega tonearm? I'm in Minnesota, but I'd ship my turntable anywhere.
Miney
  • Free your mind... and your ass will follow
http://www.britaudio.com/contact.html
 :thumb:
Give Michael a call… rewired my Kuzma Stogi… was great to work with.
saab_oteur
I spoke to Michael and he confused me: he said that both his single-ended and xlr tonearm leads are balanced.
Question for you: is one of the pins on your Stogi a ground?
Miney
Michael installed a “one piece from Cardas cartridge tags to RCA plugs Incognito rewire kit” including a separate ground wire terminated with a spade. His work looks and sounds fabulous to me.
No XLR connectors involved, so by my understanding, not balanced.
Wonder what Michael meant… maybe contact him once more, and let us know?
Paul
HAL
A phono cartridge is a balanced output device.  Typical turntable RCA cables have them wired as each connection going to the two RCA connections and the turntable ground wire only to the chassis.
You can wire an RCA hot pin to XLR pin 2 and RCA ground to XLR pin 3.  The turntable ground goes to XLR pin 1 for both channels.
Most of the RCA to XLR adapters for inputs have a different wiring scheme with the RCA ground to the XLR ground which is not a balanced connection.
I made a simple adapter box for mine.
saab_oteur
Paul
I think I’m going to send my tonearm to Stephen (talking dog transducers, inc) because he understands “true” balanced wiring. I already have the incognito kit, which is great as a single-ended connection.
saab_oteur
Looks good. I’m inept at soldering, which is why I’m going to pay someone else to do it.
djbnh
In another thread, I've been asking how to convert my single ended / RCA captive tonearm cable to balanced cables. Your adaptor box looks to be ideal. Is this something that you make for others, and if not, is there someone that you can recommend to do that work? Thanks in advance for your consideration, much appreciated.
HAL
djbnh,
I made this from parts on Amazon.  Simple to build from a plastic box, two Cardas RCA female chassis connectors. a 5-way binding post, two Rean style stereo 1/4in jacks and two XLR to TRS cables.
Just wire each of the RCA center connections to the + to pin 2 and ground connections to the - pin 3 to the Rean connector tip and ring terminals and pin 1 to the 5-way binding post and the two Rean connector ground (sleeve) terminals for the turntable ground.
This floats the RCA connector outputs for balanced operation with the cartridge coils, not grounding pin 3 to 1 like most adapters do for unbalanced to balanced connections.
Make sure to connect the tonearm/turntable ground to the 5-way binding posts to minimize hum problems.
toocool4
This is not true, not sure where you are getting your info from?
HAL
Both sides of a stereo phono cartridge float like a dynamic microphone.  That is why they have 4 wire connections.
You can use an ohm meter to check it for a MM cartridge.  Do not do it for a MC cartridge.
Some tonearms tie both the ground sides together, but that is not how it is built.
toocool4
Balanced is Positive, negative + ground, please show me how a cartridge has these 3 signals? A cartridge is Left positive, right positive, Left ground and Right ground, I don’t see how that is in your quote “A phono cartridge is a balanced output device." It's not.
HAL
From the Shure SM57 balanced output manual mic wiring diagram.
There is no ground at either the capsule or a center tap on the transformer.
The wiring of a MM is the same.  It is balance output as there is no ground.  It floats.
djbnh
djbnh,
Thanks for your kind and very detailed reply, much appreciated. To be frank, in my 68+ years that skill set simply hasn't taken residence in my wheelhouse  (making sourdough bread, that I can do haha). Again, I appreciate your kindness in explaining how you successfully made your piece of kit, nice skills.  :beer:
I.Greyhound Fan
HiFi sound in Minneapolis has a repair tech that should be able to do that for you.  Give them a call.  Also try Stereoland here in town.
If you have trouble finding someone to do it, I have a friend in town that is a retired EE.  He repairs stereo gear for a fee.  I could put you in touch with him.  He lives in Burnsville.
Where in MN do you live?  I live in Woodbury.
