Merlin Music VSM - Crossover Upgrade
0 Members and 1 Guest are viewing this topic. Read 12843 times.
jmimac351
  • Chief Instructor ChinTrackDays
Re: Merlin Music VSM - Crossover Upgrade
« Reply #40 on: 13 Apr 2024, 04:33 am »
Frederick did a great job on these!
  • Duelund CAST PP Capacitors
  • Duelund CAST Resistors
  • Goertz Copper Foil Inductors
« Last Edit: 14 Apr 2024, 03:02 pm by jmimac351 »
« Reply #41 on: 13 Apr 2024, 04:42 am »
Nice.  Looks like industrial art.
jmimac351
« Reply #42 on: 13 Apr 2024, 12:10 pm »
« Last Edit: 14 Apr 2024, 12:36 am by jmimac351 »
BrandonB
« Reply #43 on: 13 Apr 2024, 04:38 pm »
That looks very cool.  Are you going to display the crossover somehow so they can be seen?
jmimac351
« Reply #44 on: 13 Apr 2024, 09:11 pm »
Yes, I'm going to put vertical trim around them and install 3D printed tube connector mounts to the board.
jmimac351
« Reply #45 on: 25 Apr 2024, 03:25 pm »
Well, I received the crossovers last Friday and hooked one speaker up... playing Mono from my RME ADI-2/4 Pro. The other VSM enclosure showed up yesterday and I quickly got it wired up.  It's a science project right now, but I HAD to hear how the pair sounded, since just the one sounded so good... the tone was already there.
I am blown away with a few things - but not surprised, necessarily.  Recently I'd picked up a pair of Odyssey Lorelei speakers.  The price was "if I don't buy this I'm losing money"... so I bought them.  But for a reason too... they are a floorstanding speaker with the 8545 woofer (same as the VSM), and a different Scan-Speak tweeter.  Really good parts are in the crossover too - Sonicap, Goertz, etc.  What shocked me (and the owner mentioned it) was the amount of bass from the Lorelei.  It made me even more excited to hear what the VSM would sound like with more balance to the low end.
It has not disappointed.  The bass in the VSM is now HUGE... visceral - but still balanced from top to bottom.  The midrange is rich... so much so that you figure it must not have top end sparkle... but then it does and it makes you think "Wow."  The other thing that is a revelation is "Parts".  I should note, the parts I'm using in this crossover are definitely a step up from what I used in the Wilson Duette.  The Duette crossovers have Sonicap on the tweeter network, JB cap for woofer, air coil copper inductors.  Those are good parts!  For the Merlin... these Duelund parts / copper foil inductors already sound SO musical.  They already sound like what the Duette needed several hundred hours to get to.  I spent well north of $1k on parts for the VSM crossovers... I'd have to total it up.  I would spend the money again, for sure.  In fact, when I play with more speakers, the Duelund CAST PP, the Duelund CAST resistors, and copper foil inductors are probably my new baseline for what I'd use... until I hear something else and like it better.  :thumb:
If you want to use Duelund or some other parts, you can just tell Danny and Hobbs what you plan to do.  Or, do the build he has a receipe for.  I am sure the Sonicap setup is great too, but there is a difference between Sonicap and Duelund.  It's possible the Sonicap is more to your liking / pairs better with your gear.  This is the 3rd pair of crossovers I've started the burn-in process for, since December.  Twice on the Duette, and now the VSM. Parts Matter.  I am absolutely thrilled with how this is turning out.  I have a plan for how I'm going to finish off the crossovers, but it will be a struggle to disconnect them to do it!
This was not hard to do and doesn't require a permanent mod to the speaker. The removable rear panel makes this easy.  If you need help, reach out to me.  I'm glad to help with a few tips once you pull the rear panel / crossover.
It's really cool when you go thru a lot of effort and expense... and it works out even better than you could have hoped for.  I'm having a lot of fun.
Thank you, Danny.
Early B.
« Reply #46 on: 25 Apr 2024, 03:37 pm »
Very cool!
« Reply #47 on: 25 Apr 2024, 04:54 pm »
VSM's were already pretty good speakers, sounds like they are now world-class speakers after the upgrade.
jmimac351
« Reply #48 on: 16 May 2024, 02:58 am »
So... I got to thinking... I'm collecting parts for NX-Studio speaker, and I was looking at the levels / curves of the drivers.  I was doing the same with the Merlin VSM crossover Danny just did.  And I thought... "I wonder..."
And then I looked at the bolt circle for the 8545 and M165NQ.  Yep, it's the same.
How about efficiency?  Yep, the same.
Impedance?  Same.
Why won't this work?  Well, I just got this running tonight, and I am trying to contain my enthusiasm!!!
The M165NQ works great in a ported box.  I meant to take exact measurements of the internal volume of the VSM when swapping drivers.  I will do that, and measure the port.
I need to get my REW / UMIK microphone setup running to take a measurement.  I wish we'd thought of doing this when I had the speaker with Danny.
jmimac351
« Reply #49 on: 16 May 2024, 10:57 pm »
When I put this comparison together, I knew I had to try it.
I've read the NQ drivers can use some break-in... something like 80hrs (I think).  I am putting them thru their paces.  They will get about 10hrs of play every day, minimum.
I will play with the 8545 and M165NQ.  They will have the same parts on the woofer networks... Duelund CAST PP and Goertz inductors, Duelund CAST resistors. Well, except for the NQ driver.  It only has 2 parts - cap and inductor!  The 8545 in the Merlin VSM has 6 parts.
Right now on the NQ woofer network I have a spare Sonicap and US Coils air core inductor.  It's ultra clarity but with no fatigue.  It's not clarity from being forward, as the low end is still balanced.  It does not play as low as the 8545, but the midrange is ultra detailed... but again without being forward or fatiguing.  It's just a different thing.
« Reply #50 on: 17 May 2024, 12:33 am »
IME, the 8545 is more of a mid/bass woofer and the M165NQ is more of a no-compromise pure midrange driver (that also happens to be able to do decent bass).
jmimac351
« Reply #51 on: 17 May 2024, 03:33 pm »
That was my understanding as well, and that's what it sounds like.  Want a woofer to play up well into the midrange... won't play as low, and vice versa.  And then there is the Purifi driver... which I've never heard.  Now, an NX-Studio with this M165NQ and a few 8545 drivers below it to fill out the bottom end / impact with a sub amp to dial them in... that would be an interesting, slim, floorstanding speaker.  I have 4 of the 8545 drivers here.
When asked about a "NX-Studio floor standing speaker" I think Danny suggested doing it that way... with a sub amp driving the lower drivers so they can be dialed in, and also avoid the large cap(s) needed for the low end drivers. Here is a setup that does exactly that, with Purifi woofers and Hypex sub amp that allows DSP configuration of the low end.  For similar money, could just have subs, but more floorspace needed.
An "Add On Low End tower" in a flatpack with drivers / amp for the Studio to sit on would probably have interest, I think.  Some people are perfectly happy with low end playing to low-30s.  I can listen to my Wilson Duette playing by themselves doing just that.
