Wanted: EAD DSP-7000 looking for a EAD Dac
0 Members and 1 Guest are viewing this topic. Read 964 times.
SylvainQc
  • Music, Tube fan, vintage gear.. living in Quebec
« on: 17 Nov 2023, 03:57 pm »
Hi, I'm looking for an EAD DSP-7000, if possible Mk3 but not mandatory. Must be in good working order. Aesthetics not really important. Mine died lately it seems.. and that's the sound I was used to and that matched my system. I know there are modern better Dacs.. but I don't feel like going through that search process again. Rather just to listen to some good music. Thanks for reading.  :wink:
Charles Xavier
Re: Wanted: EAD DSP-7000 looking for a EAD Dac
« Reply #1 on: 17 Nov 2023, 04:29 pm »
https://www.nobleelectronics.net/
See if these guys can fix it.
Ron D
« Reply #2 on: 17 Nov 2023, 06:29 pm »
Sylvain, given your location I assume you also frequent Cauckaudiomart and I would post the same thing there if you haven't already. Should you decide to repair your unit if you find a CDN based credible repair shop it might in the end cost you less. Good luck whichever path you take.
« Last Edit: 18 Nov 2023, 02:55 am by Ron D »
