How to connect SVS PB-1000 to DAC-9 w. dual bridged STA-9
Diavolo68
Hi I’m new here. Have loved the Nuprime stuff since I bought a Nuf**** desktop amp ages ago (with its odd RJ45 speaker cables).
I’ve finally added a sub to my setup (DAC-9, 2x STA-9 bridged, Bluesound Node streamer, LTS 3-way fullrange speakers). Much needed. My living/listening room is 7000 cubic feet (12’ ceiling height). Even though the speakers have a high sensitivity and can play really loud, the back firing bass is not enough.
But my question is, how do I set this gear up with an SVS PB-1000? I’ve bridged the two STA-9’s and use XLR between the DAC-9 and STA-9. Can/should I use XLR for the sub as well, if so how do I connect them? Or do I go RCA?
John Casler
Re: How to connect SVS PB-1000 to DAC-9 w. dual bridged STA-9
« Reply #1 on: 16 Nov 2023, 03:24 pm »
Yes, if you use the XLR to the STA9, then use the RCA to the subs.
