Schiit Vidar2 Monos or Tyr's for Brutes?
0 Members and 1 Guest are viewing this topic. Read 9165 times.
Presb4
« on: 12 Nov 2023, 04:06 am »
I am looking for some new Schiit.
I have 1 Vidar 2 for stereo HT use but I am looking for more power and better dynamics. Should I pick up another Vidar 2 a try them as monos with my GR Brutes or should I just upgrade to the Tyr's and sell my one Vidar 2?
Im sure some of you out there have had this question or have already demoed these combos and would love to know what your opinions are.
corndog71
  • Some people call me Rob.
Re: Schiit Vidar2 Monos or Tyr's for Brutes?
« Reply #1 on: 12 Nov 2023, 04:15 am »
I haven’t heard the Vidar but the Tyrs are fantastic amps.  Effortless control, air, and dynamics.  Best amps I’ve ever owned.
Presb4
« Reply #2 on: 12 Nov 2023, 06:47 pm »
Thanks for the comment Corndog.
What other amps have you had with your system that you directly compared to the Tyr's and what was the most significant changes. What pre-Amp are you using with them. I have a Schiit Freya+ that I would be using with the Tyr's, any comment on that combo? Also as the Tyr's run in a semi Class A bias, can you comment on how hot they get, how much they heat your room compared to other class AB amps or tube amps you may have.
Thanks.
SRP SRP
« Reply #3 on: 12 Nov 2023, 08:28 pm »
The Tyrs are tempting. They will likely be my next amp purchase. I have a couple of Vidars running nx studios.
You can always return them if you aren’t blown away…
Presb4
« Reply #4 on: 12 Nov 2023, 09:18 pm »
Can you speak to the difference between running one Vidar vs running 2 as mono blocks and your NX Studios?
Hobbsmeerkat
« Reply #5 on: 12 Nov 2023, 09:54 pm »
We had the Tyrs over in the listening room for a bit while Danny's big chip amps were out of commission and he was quite impressed with them.
I didn't really get a chance to sit down and listen to them tho.
Presb4
« Reply #6 on: 12 Nov 2023, 10:05 pm »
Hobbs were you all using a Dodd Pre with that set up or something else?
Hobbsmeerkat
« Reply #7 on: 12 Nov 2023, 10:15 pm »
Yup the same Dodd DAC & Pre as always.
corndog71
« Reply #8 on: 12 Nov 2023, 11:11 pm »
Thanks.
Ok, to be fair I haven’t had a ton of amps to compare but I’ve been in this hobby long enough to know a good thing.
Previously I was using a pair of highly modified 140 watt tube amps which I thought sounded pretty great.  Tyr just walked all over them.  I’ve also used Marantz, Denon, and Outlaw receivers.  Marantz is my favorite of the bunch but they’re still receivers with lots of compromises.
My main preamp is a Gain Cell Dac from PS Audio.  One of the most transparent preamps I’ve heard under $2k.  The built in dac is not as good as my Schiit Yggdrasil.  It’s a great preamp though and has balanced outputs.
The Tyrs run pretty cool actually.  I rarely get to crank them up but I’ve never felt them get hot.  I’ve had them on for most of a day while gaming, playing music at a moderate level and watching tv and they still never got hot.  I think my Yggdrasil dac runs warmer than Tyr.
AllanS
« Reply #9 on: 12 Nov 2023, 11:46 pm »
Interesting comparison.  I have a GCD paired with PS Audio M1200 and am contemplating a change.  I've not considered the Tyr because they're beasts and the thought of $200 shipping per amp scares me a bit.
I'd hesitate to audition the Tyr because the Ragnarok 2 I had tended to be a bit on the bright side which I do not like.
Considering your Marantz preference and tube experience how would you characterize the Tyr sound?
jmimac351
« Reply #10 on: 13 Nov 2023, 12:59 am »
« Last Edit: 5 Dec 2025, 06:49 pm by jmimac351 »
jmimac351
« Reply #11 on: 13 Nov 2023, 01:12 am »
corndog71
« Reply #12 on: 13 Nov 2023, 01:52 am »
Tyr throws a wide and deep soundstage.  I do not think of them as bright at all.  They seem very well balanced.  I’ve tried them with all of my speakers and they drove them all well.  They definitely work better with better gear.  They’re both fast with dynamics and sublime with mellower music.  Can you tell I really like them?
I just remembered something.  Earlier this year I heard a couple of Hegel integrated amps driving Mofi Sourcepoint 10 and Amphion speakers.  They both were killer combos.  Very transparent with big lifelike soundstaging.  In comparison to Tyr the Hegel amps initially seemed to be better overall but they were different in a particular way.  They were more forward sounding.  While imaging was impressive, the soundstage was like a big wall at the same distance as the speakers.  Maybe it was the speakers.  But it was a very different experience vs the Tyrs.
The Tyrs make drum kits sit 6’ behind the speakers.  I hear lots of air and space in recordings.  They make piano sound more real.  They never seem to run out of steam.  Granted all of my speakers are fairly easy to drive.
I shot a video of them playing some Star Wars music:
https://youtu.be/9Ao_taobq44?si=kHunQWYHOHTxPrIV
AllanS
« Reply #13 on: 13 Nov 2023, 03:32 am »
Thanks much for your thoughts.
I’ve never heard any Hegel gear but have heard comments that what they offer is superb but lacking depth.
Presb4
« Reply #14 on: 13 Nov 2023, 04:36 am »
Thank you all for your input.
Jmimac351, I especially appreciated the comments around the dampening factor needing to work with the speaker Q factor. I have read other information in the past provided by John Devor speaking to the Dampening/Q effects but had forgotten it until it was mentioned here again. I see your point that using an amp with high dampening in the 1000+ with a speaker that is also high Q would be to much for musicality and create a more thin overall sound, maybe even clinical.  :o
My Dynaco ST-70 has a dampening factor of around 40 I think, and when connected to the Brutes, the bass sounds very good. My Schiit Vidar 2 controls the Brutes bass better then the ST-70 for sure. But if the Vidar2 was a perfect 10 at controlling the Brutes, then my ST-70 would be an 8, which I am surprised to say being thats its a tube amp.
I agree that the 15 day free trial is not anywhere close to free once you pay to ship the Tyrs to you and if you dont like them, pay again to ship them back. That would suck. But I have read such good reviews from owners who have first hand experience here on AC and over on HeadFi that it sounds like low risk.
I went ahead and placed an order for the Tyr's tonight and will report back on how they compare with the Vidar 2 and my GR Brute combo once I have some time with them.
jmimac351
« Reply #15 on: 13 Nov 2023, 04:47 am »
Cool!  I bet you'll like them.
AllanS
« Reply #16 on: 13 Nov 2023, 11:54 am »
Good to know you learned enough to pull the trigger.  Looking forward to your impressions.  Now sit and wait…
AllanS
« Reply #17 on: 13 Nov 2023, 01:31 pm »
Why bring this up at all?  Speakers with a "High Q" design have "built-in" damping.  If you have an amp that wants to damp the speaker with higher damping factor (control) it may sound "thin"... not as "musical".  I seem to recall that the Eminence woofer is High'Q??? What's the best amp needs to be put into context of not just "what sounds best", but how that amp is going to interact with the electrical properties of the speaker.
This is the kind of stuff that makes this hobby both fascinating and frustrating.  In the context of amps I’m familiar with the term damping but not the details.  It never crossed my mind but it makes complete sense that speakers would have their own damping characteristics and that too much of a good thing is bad.
jmimac351
« Reply #18 on: 13 Nov 2023, 02:24 pm »
Danny Richie
« Reply #19 on: 13 Nov 2023, 05:53 pm »
The Tyr mono blocks aren't going to dethrone my reference amps or any Dodd tube amps, but they did sound really good. I was surprised by just how good they sounded, especially for the price. I'd recommend them.
