Sennheiser Momentum 4
Freo-1
« on: 9 Nov 2023, 09:31 pm »
Recently picked up a pair of Momentum 4 headphones for travel.  Very happy with their performance.  The noise cancelling function works quite well, especially on aircraft.  Lots of adjustments available.  Comes with a nice hard carrying case, and one of the very few wireless cans that also be used wired, which is a nice backup option.
The Momentum 4 is also supported by the SoundID software from Sonarworks.  Recommended for audition for wireless/travel use.
newzooreview
Re: Sennheiser Momentum 4
« Reply #1 on: 9 Nov 2023, 09:43 pm »
I returned my pair due to channel imbalance. It's good you found a pair without that issue. The issue seemed to come up in a couple of reviews.
Freo-1
« Reply #2 on: 9 Nov 2023, 09:45 pm »
No issues with channel imbalance.  The most recent SW drop seemed to further improve the sound.
