0 Members and 1 Guest are viewing this topic. Read 19467 times.
Cool! I'd be interested in your report on the sound without the ARC engaged. I'm also curious what your HT system would sound like without the G25HP's. In such a small room, the double troubles should be all the bass you'd ever need. Of course, you'd have to adjust the A370's to get them to sound like HT subs.
The ARC surround and height curves look good.You can roll off the L&R front speakers lower if the amp has the power. I adjusted my L&R curve to 50 Hz, the Salk HT2-TL go down to 34 Hz and 50 Hz gives me a little headroom with 225 watts per channel.My sub curve is close to yours.I also used the internal pink noise to check levels with a sound meter after ARC calibration. Then I double checked by playing pink noise from a Stereophile test disk, the reading were slightly different. I have 4 amps so pairs of speakers can be turned off for an accurate reading. I ended up boosting the level of the height and Atmos speakers to get everything reading 70 dB.Finally Dune was playing at one of our best theaters and I was able to compare what I heard in the theater to a ripped Blu-ray I keep for demo purposes. After a little tweaking the surround sound and volume I achieved is identical to the theater sound.
Stunning accomplishment!
I’m bet if you were able to roll off the Studios higher, say 120hz., I bet the congestion would clear up.
I’m bet if you were able to roll off the Studios higher, say 120hz., I bet the congestion would clear up. Rocket Ronny
Yep. You ain't hearing the Studios properly until you dial them in with the A370s. Your perception of their midrange depth relative to the NX-Oticas will likely change.
You said you have your doubles crossed at 80 with your Studio’s. What are the other settings that you use?
I don't have Studios, so my amp settings will be of no value to you.
That looks cool, but it isn't the braces that need the No Rez. It is the panels that need the No Rez.
Oh yeah, I’m aware. I was just starting with the bracing so I could get the correct measurements for all the paneling. I’m doing the bracing because I didn’t like what I was hearing when I knocked on it. I had some extra work to do on the bracing because of an issue I noticed with them. It’s why I grabbed an extra 4 sheets of No Rez in the last sale. If I have enough I’m also planning on putting sheets on the bottom of the bottom plate of the Otica’s and Subs between the feet. It’s probably over kill but I don’t mind.
It is not a problem.
You have been listening to your speakers for awhile without No-Rez. Without measurements did you hear a difference and how much did you notice when you added NoRez to your speakers?
