Computer Volume Control
Early B.
« on: 15 Oct 2023, 11:47 pm »
It's annoying to constantly adjust the volume anytime I switch between websites or even between YouTube videos. Is there a way to maintain a constant volume level on my desktop computer? (there's a term for this, but I don't recall it). Thanks.
Re: Computer Volume Control
« Reply #1 on: 15 Oct 2023, 11:56 pm »
Try Select Playback Device or right button click onthe speaker icon, many sites adjust sound, colours or fonts.
Mag
« Reply #2 on: 16 Oct 2023, 12:00 am »
   Not sure if I can help you. On Windows 10, I go to Advanced Sound options and adjust the Master Volume to 50%. Other Apps I can adjust the volume levels as well.
  With music there's always variation as songs are recorded loud to quiet. You can use Normalization to level sound volume, I don't use it because it ruins the dynamics of songs.
