midwoofer upgrade technical question
0 Members and 1 Guest are viewing this topic. Read 1658 times.
woodsyi
« on: 30 Apr 2005, 02:56 pm »
The new mid woofers are not marked.  I am assuming that left post as I am looking at the back of the woofer is positive like it is on the old woofer.  Am I right?
Brian Cheney
    • http://www.vmpsaudio.com
woofers
« Reply #1 on: 30 Apr 2005, 03:08 pm »
Yes.  You can check with a 9V battery, touch the (+) battery terminal to the righthand lug, the (-) to the other lug, cone should move forward.
woodsyi
« Reply #2 on: 30 Apr 2005, 03:15 pm »
One more question.
As I was adding the caps to the Neos, I noticed a disconnected wire on the tweeter filter.  The part marked f333k? 250pp1 is broken.  Where can I find a replacement.  It must have been like that for a while but all drivers were working.....
Brian Cheney
part
« Reply #3 on: 30 Apr 2005, 05:45 pm »
Send us the part and we'll send you an exact replacement.
B
woodsyi
« Reply #4 on: 30 Apr 2005, 05:56 pm »
OK Big B.
I will send it out Monday.
woodsyi
« Reply #5 on: 3 May 2005, 06:42 pm »
Big B.
No one was home at Itone. :bawl: Can you sign the release so that you can get it tomorrow even if UPS misses you again.  I would like the replacement by Friday if you have it in stock.
