OB driver placement question
0 Members and 1 Guest are viewing this topic. Read 2266 times.
DRG
« on: 18 Sep 2023, 02:51 am »
HI folks:  O bought a pair of the Betsy PB speakers, the 8" drivers.  I noticed that the drives are mounted on the baffle, but there are versions where the driver is mounted from behind, leaving a bevel on the front of the baffle.  Question I have:  will the sound be any different depending on the driver mount?  Thank you
Re: OB driver placement question
« Reply #1 on: 18 Sep 2023, 04:13 am »
Yes. The dispersion pattern will be different, slightly less dispersion,
it would impact the sound stage the listener perceives.
« Last Edit: 18 Sep 2023, 05:34 am by FullRangeMan »
opnly bafld
« Reply #2 on: 18 Sep 2023, 01:45 pm »
Not a Betsy PB speaker (whatever that is), looks like a Lii Audio driver.
https://wildburroaudio.com/speakers/
Why don't you ask Caintuck Audio if there is any difference?
Thin baffles front mount, thick baffles rear mount.
Nothing to worry about with larger wideband drivers IMO
T4Man
« Reply #3 on: 18 Sep 2023, 02:39 pm »
Those look like the Decware Zen Master speakers. Clone?
opnly bafld
« Reply #4 on: 18 Sep 2023, 04:35 pm »
 The Decware's are the clone.
http://www.caintuckaudio.com/
« Last Edit: 18 Sep 2023, 11:05 pm by opnly bafld »
DRG
« Reply #5 on: 18 Sep 2023, 05:03 pm »
thank you all for the replies.  I admit, I do not know if this is a Betsy, but YES, it is the lIl Audio 8" drivers.  i bought them used.  They sound very clean so I am pleased.   Thank you for the help
opnly bafld
« Reply #6 on: 18 Sep 2023, 08:58 pm »
Wild Burro Betsy
T4Man
« Reply #7 on: 21 Sep 2023, 05:52 pm »
