VM540ML or ML140/OCC
henrylr
« on: 29 Aug 2023, 09:17 pm »
What would you buy a new Audio-Technica VM540ML for $279 or a used AUDIO TECHNICA VM  AT-ML140/OCC ML for $256,  in excellent, tested condition, from a vendor in Japan with 100% feedback? I think the ML140 with a much lower tracking force of 1.25gram, better channel separation and greater frequency response is enticing.
henrylr
Re: VM540ML or ML140/OCC
« Reply #1 on: 2 Sep 2023, 11:33 pm »
I put the AT vm540ml on my Pioneer PL-707 and the sound is fantastic. It is like night and day compared to my Grado Prestige Blue.
Rocket
« Reply #2 on: 3 Sep 2023, 04:42 am »
Hi,
I'd be reluctant to buy a secondhand cartridge unless I personally knew the person.
Glad your happy with the results of the audiotechnica cartridge.
Cheers Rod
henrylr
« Reply #3 on: 3 Sep 2023, 03:26 pm »
While the VM540ML sounds great, there was one disappointment. The gold platted connectors on the wire leads were not round and the opening was so small that they could not be forced on the pins. I had to use a large sewing needle to reshape and enlarge the opening.
Rocket
« Reply #4 on: 4 Sep 2023, 09:59 am »
Hi,
I used a Audio-Technica AT-VM95SH Dual Moving Magnet Cartridge and I had good results with my Bryston turntable. I'm now using a Goldring gx1012 mm with my Technics sl1200g.
Cheers Rod
